Home > Maintenance & Mods (L322) > "stretched" Tow Ball Protection Plate |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Blimey... |
18th May 2015 8:36pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7925 |
That's a few spacers
18th May 2015 8:41pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Bringing it out further from the bumper reduces the amount of vertical load you can have on the tow ball. So i would imagine they've kept it close to keep the vertical load limit as high as possible. |
19th May 2015 12:16am |
Yep, I have the MaxRaxx as well but when I measured it from the centre line of the rear wheels the extra 36mm made a massive 2.97% difference so the maximum vertical load of 150KG (250KG if you reduce the max load in the boot by 100KG) was about 4 kilos. Since the caravan hitch and the one on the Ifor Williams are max rated at 100KG it doesn't matter.
19th May 2015 7:06am |
devonchilliman Member Since: 06 Jan 2015 Location: Devon Posts: 345 |
tis for a very good reason ...unlike you chaps with tin tents ,I very rarely park on nice flat level ground when I have the trailer on,so as you unhitched & level up the trailer the drawbar ends up as high as or even higher than the bumper and more often than not the drawbar extends out towards the FF,so it's only a matter of time before the bumper is ...I know i look stupid Oh and only one spacer used @dom Last edited by devonchilliman on 19th May 2015 8:57am. Edited 1 time in total |
19th May 2015 8:43am |
Cliff, did you just accuse me of owning a tin tent sir |
19th May 2015 8:46am |
Would I ever...just the likes of Dom |
19th May 2015 8:56am |
Like ide get the time to use it
19th May 2015 8:57am |
Garry was asking if I have the actual speed displayed in numbers on my dash and if I don't it's an enablement that you can do,is this so? |
19th May 2015 8:59am |
Hey, now then.....I've got an Ifor as well |
19th May 2015 9:03am |
19th May 2015 9:05am |
It "tis" yes sir... |
19th May 2015 9:21am |
So that's 3 reasons to visit you now |
20th May 2015 8:20am |
Indeed... (but i forgot the other two) |
20th May 2015 8:24am |
