Home > Maintenance & Mods (L322) > central locking / folding mirrors / upgrade |
viper Member Since: 11 Apr 2015 Location: manchester Posts: 271 |
I purchased a module that will allow the mirrors to fold when the car is locked . My 2007 fatty does not have this built into the system. Im almost there with the install and will publish some info when its complete. For now ive got the unit working as it should folding the mirrors in and out along with the central locking of the car.
18th May 2015 4:38pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3234 |
Not done one but wonder if the fact that the passenger mirror has automatic tilt if driver's side is selected will make a difference? John
18th May 2015 5:08pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35315 |
shouldnt make a difference John as the one switch on the drivers side closes and opens both at the same time regardless where the 'dip mirror' switch is...
18th May 2015 5:51pm |
John
18th May 2015 6:05pm |
no its not that, ive found all the wires that control the mirror dip . The passenger mirror just has one wire that seems to be 12v all the time , which does have a voltage fluctuation on it when the mirror fold button is depressed. The drivers mirror is wired in a conventional way but the passenger mirror is some fancy jiggery pokery. when I get some more time next week I will take off the passenger door card and try to get at the motor wires direct . if I do it , it will be a really smart bit of kit, you guys with 2009 + cars don't know how lucky you are! |
18th May 2015 8:00pm |
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 341 |
http://www.fullfatrr.com/gallery/albums/userpics/10998/Mirror.pdf
18th May 2015 8:43pm |
actually that wiring diagram is of use, what it tells me is that the passenger side does have the same wiring set up, however its from a module probably behind the passenger door card and I will need to run some wires from the passenger side to the drivers side through both door /pillar posts,
18th May 2015 9:02pm |
..........or fit another unit on the passemger side Neil.. ... - .- -.
19th May 2015 7:43am |
yes stan,great minds think alike , ive ordered one yesterday , just so much easier than running wires through the doors . Although I may need to run a switch live into the door as ive not found one as yet
19th May 2015 8:16am |
Wylie66 Member Since: 10 Jan 2016 Location: Bushey Posts: 67 |
Sorry to drag up an old thread but did you manage to get this working?
29th Feb 2016 11:06am |
