Home > Maintenance & Mods (L322) > central locking / folding mirrors / upgrade
viper
I purchased a module that will allow the mirrors to fold when the car is locked . My 2007 fatty does not have this built into the system. Im almost there with the install and will publish some info when its complete. For now ive got the unit working as it should folding the mirrors in and out along with the central locking of the car.
To achieve this you need to find the wires going into the mirrors that control the in and out motion. Ive done this today after a considerable amount of time with a meter. The drivers mirror is solved and ive got the correct combination of switching wires. However the passenger mirror seems to be wired differently . that mirror just seems to have 1 x 12v wire controlling both in and out that appears to have a pulse done it which tells the mirror what to do , so im struggling to get the passenger mirror functioning as the drivers one does.
ive done the instal from the switching panel in the drivers door and have not taken off the passenger door card yet, maybe the answer will lie in that wiring ?
has anyone fitted one of these before , any tips ?
Post #328475 18th May 2015 4:38pm
Weegie
Not done one but wonder if the fact that the passenger mirror has automatic tilt if driver's side is selected will make a difference? John
GAP iiD BT
Post #328479 18th May 2015 5:08pm
shouldnt make a difference John as the one switch on the drivers side closes and opens both at the same time regardless where the 'dip mirror' switch is...
glad to see you making progress viper Thumbs Up ... - .- -.
Post #328483 18th May 2015 5:51pm
Weegie
Thumbs Up John
GAP iiD BT
Post #328487 18th May 2015 6:05pm
viper
no its not that, ive found all the wires that control the mirror dip . The passenger mirror just has one wire that seems to be 12v all the time , which does have a voltage fluctuation on it when the mirror fold button is depressed. The drivers mirror is wired in a conventional way but the passenger mirror is some fancy jiggery pokery.
when I get some more time next week I will take off the passenger door card and try to get at the motor wires direct .
if I do it , it will be a really smart bit of kit, you guys with 2009 + cars don't know how lucky you are!
Post #328509 18th May 2015 8:00pm
stenh02
Scotland 2004 Range Rover Vogue 4.4 V8 Rimini Red
http://www.fullfatrr.com/gallery/albums/userpics/10998/Mirror.pdf
Any use?
Post #328525 18th May 2015 8:43pm
viper
actually that wiring diagram is of use, what it tells me is that the passenger side does have the same wiring set up, however its from a module probably behind the passenger door card and I will need to run some wires from the passenger side to the drivers side through both door /pillar posts,
thanks , much appriciated
Post #328529 18th May 2015 9:02pm
..........or fit another unit on the passemger side Neil.. ... - .- -.
Post #328564 19th May 2015 7:43am
viper
yes stan,great minds think alike , ive ordered one yesterday , just so much easier than running wires through the doors . Although I may need to run a switch live into the door as ive not found one as yet
thanks everyone
Post #328571 19th May 2015 8:16am
Wylie66
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zermatt Silver
Sorry to drag up an old thread but did you manage to get this working?
I have just ordered 2 units based upon the advise offered, and would like to be prepared. Any advise or wiring diagrams would be appreciated.
John 2003 V8 Vogue in Silver
Post #374842 29th Feb 2016 11:06am
