![]() | Home > Technical (L322) > Cooling fan control circuit malfunction |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
I've just replaced the fan on mine. Kept blowing the fuse and smoke came from the motor when you replaced the fuse. Is the electric fan actually running? Fuse ok? |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 325 ![]() ![]() ![]() |
Didnt know it had a fuse for it.
In the glove compartment fuse box there are 4 large maxi fuses. It's the 1st one from the left. |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
I think you are confusing the viscous fan with the electric one. There is a separate electric fan in front of the A/C condenser which also helps with normal cooling if needed (if the coolant temp gets too high). It's a standard BMW set-up, in cooler climates you can even get away with ditching the viscous fan completely and just using the electric fan. |
The viscous fan isn't what's throwing up the fault code though.
