Home > Technical (L322) > Full tank..... Empty Tank..... Full Tank!
Filled up the other day, pretty much to the brim.
Got in today, and the fuel gauge cant make its mind up if its full or empty. Right hand corners give empty, left is full to the brim. Big Cry
Sounds like a dodgy sender, any one have any idea how tricky they are to change? Gonna have a look on rave but i may find that after I've used a little of the fuel it will settle down, or not.
Its not been run since monday so maybe its in a bit of a mood with me Rolling Eyes There is nothing that can't be fixed with a hammer😜😜
Post #216260 13th Oct 2013 11:07am
edit.
Just looked at rave and apparently there are two senders and the dash panel takes an aggregate reading off both sensors and calculates a level.
Either way they seem to be attached to some gubbins in the bottom of the tank and as such require an empty tank to do the job. So i guess it will have to wait until there is not much diesel left. There is nothing that can't be fixed with a hammer😜😜
Post #216262 13th Oct 2013 11:18am
i reckon this will help,
http://www.fullfatrr.com/forum/topic16152.html ... - .- -.
Post #216263 13th Oct 2013 11:20am
Googsy
This happened to me too I put it down to an airlock as it righted itself after about a week and has not happened since that was about 2 years ago Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #216275 13th Oct 2013 12:28pm
Ok, thanks chaps.
Looks like a pig of a job to change so if it doesnt fix itself, through a bit of sucking up to the car (wash, polish and hoover) then it will be off to the dealer.
I have just checked the warranty i have and the "sender unit" is included in covered parts the only exclusion is if i have put petrol in the car. which i may have noticed.
I have taken a video of the needle flicking back and forwards so it the tec cant replicate it at least i can show him.
Looking at thread stan has put up, i reckon i may get my moneys worth out of the warranty for this year (if they pay up) as its a fair amount of labour to just get to the parts.
I have done this kind of job before on an old pug i had, was fairly straight forwards once i had gotten to the tank but there looks to be a lot of trim removal to do beforehand on the ff.
Having just been out and switched it on it is now reading full........ was empty when parked up......... it seems to have had a change of heart.
At least i reset the trip when i filled it up last week so i have a fairly good idea of how much fuel is in it..... There is nothing that can't be fixed with a hammer😜😜
Post #216287 13th Oct 2013 2:41pm
After pretty much the whole day not working......
It has mended itself. Possibly caused by a completely full tank, now it has dropped just below full al seems to have returned to normal Rolling Eyes There is nothing that can't be fixed with a hammer😜😜
Post #216301 13th Oct 2013 5:04pm
Charmer
Did this ever come back?
I have got exactly the same issue at the moment.
Post #326559 7th May 2015 4:35pm
yes it did, was fine for a time but in the end it started giving wrong readings, so i replaced the intank unit, and all is good again. There is nothing that can't be fixed with a hammer😜😜
Post #326568 7th May 2015 6:07pm
Charmer
I had a horrible feeling that was going to be the case.
Any idea of the likely cost?
Post #326590 7th May 2015 7:50pm
Whats wrong with yours? The same as above or always reading 1/3rd of a tank?
Post #326602 7th May 2015 8:42pm
Charmer
Goes from showing empty to full and then back to empty and so on every minute or so.
Post #326607 7th May 2015 8:54pm
I ask as there are two different problems sir... But if yours is showing the same symptoms as above then, that answers that... Thumbs Up
Post #326661 8th May 2015 8:20am
