Home > Technical (L322) > Full tank..... Empty Tank..... Full Tank! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8499 |
edit.
13th Oct 2013 11:18am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35248 |
i reckon this will help,
13th Oct 2013 11:20am |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
This happened to me too I put it down to an airlock as it righted itself after about a week and has not happened since that was about 2 years ago Present :2008 TDV8 HSE
13th Oct 2013 12:28pm |
Ok, thanks chaps.
13th Oct 2013 2:41pm |
After pretty much the whole day not working......
13th Oct 2013 5:04pm |
Charmer Member Since: 28 Aug 2012 Location: Alton Posts: 156 |
Did this ever come back?
7th May 2015 4:35pm |
yes it did, was fine for a time but in the end it started giving wrong readings, so i replaced the intank unit, and all is good again. There is nothing that can't be fixed with a hammer😜😜
7th May 2015 6:07pm |
I had a horrible feeling that was going to be the case.
7th May 2015 7:50pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16267 |
Whats wrong with yours? The same as above or always reading 1/3rd of a tank? |
7th May 2015 8:42pm |
Goes from showing empty to full and then back to empty and so on every minute or so. |
7th May 2015 8:54pm |
I ask as there are two different problems sir... But if yours is showing the same symptoms as above then, that answers that... |
8th May 2015 8:20am |
