Home > Technical (L322) > Check Coolant Sensor |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
Hi Trevor,
2nd May 2015 8:38pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
Has the coolant been recently changed?
2nd May 2015 8:47pm |
Trev18 Member Since: 23 Apr 2013 Location: North Manchester UK Posts: 267 |
Thanks Guys... Look like trial and error here then..
3rd May 2015 4:26pm |
That I don't know. Mechanic didn't give me an option, but if it's prone to problems OME is the safest. |
3rd May 2015 6:59pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
new tank is about £50 from Land-Rover (plus the cap) had this conversation with the parts guy the other day. |
3rd May 2015 7:02pm |
jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259 |
just before you go and shell out some hard earned,
5th May 2015 9:55am |
Jake,
5th May 2015 7:57pm |
The Brains Trust Member Since: 23 Sep 2011 Location: Melbourne Posts: 155 |
Had the same problem for ages - checked and rechecked the coolant concentration, etc to no avail. I was using some aftermarket blue stuff that was supposed to be a direct replacement for the OEM coolant. In the end, I dropped that and put new OEM coolant in it and the fault went away instantly. |
13th May 2015 8:16pm |
Thanks..
13th May 2015 9:05pm |
Found this on Topix
14th May 2015 1:52pm |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 |
PDA500300 You can paypal direct using - www.paypal.me/duckworthparts
14th May 2015 1:55pm |
Thanks Dan,
14th May 2015 1:59pm |
Hi Trev
14th May 2015 2:46pm |
Ok..
14th May 2015 4:50pm |
