Home > Technical (L322) > Check Coolant Sensor
Trev18
United Kingdom 2005 Range Rover Vogue SE Td6 Zambezi Silver
Hi all
I have had the bong and check coolant message since February..
I have checked the coolant and no Loss..
I have changed the cap (given the 145 written under the cap version as per car spec)
I have just had the sensor changed and still the message doe not go away..
The one removed, did not have a black cover on it... The new one did....
Should this be removed... It did not seem to want to come off and we didn't what to break it by forcing it off..
Regards
Trev Current Cars
(Sold) Range Rover TD6 05 Vogue SE - 85k - Zambezi Silver - Black Leather..
Kia Ceed (4) 1.6 - 33k - Silver
Previous.
VW Golf 2008 2.0 SDI (With Add Ons) - 109k Silver
Vauxhall Zafira 2.2 Petrol SRI - with Ex Pack 32k -Turquoise (traded for the FFRR)
Post #325549 2nd May 2015 4:22pm
RR2008HSE
Hi Trevor,
Yep, been there. Done that. Stymied one mechanic completely.
So, you're got loosing coolant, you have the correct coolant and it's in good condition, and the sensor is good. Right?
I had the same problem (2008, petrol VCool. It's the coolant tank. They can give problems and JLR has redesigned the tank because of it. For me, getting a new tank repaired the problem and there have been no coolant warnings in since the repair (9 months). TOUCH WOOD.
I had my indie mechanic do the whole job for the equivalent of £100 including labour.
Good luck.
Post #325594 2nd May 2015 8:38pm
Has the coolant been recently changed?
The level sensor spent check the physical level of the liquid, it checks the specific gravity of the coolant. So if you haven't got a strong enough mix it will give a low reading. There is nothing that can't be fixed with a hammer😜😜
Post #325597 2nd May 2015 8:47pm
Trev18
Thanks Guys... Look like trial and error here then..
Yes the coolant is correct mixture...
I will price up a new tank... I take it needs to be a Genuine one.....
Trev Current Cars
Previous.
Post #325784 3rd May 2015 4:26pm
RR2008HSE
That I don't know. Mechanic didn't give me an option, but if it's prone to problems OME is the safest.
Post #325837 3rd May 2015 6:59pm
Zirconblue
new tank is about £50 from Land-Rover (plus the cap) had this conversation with the parts guy the other day.
Post #325840 3rd May 2015 7:02pm
jakebullet64
United Kingdom 2003 Range Rover Vogue 4.4 V8 Santorini Black
just before you go and shell out some hard earned,
just give it a good drive on the m'way.
mine was doing the same for a few days. but after a trip to aberystwyth its now gone. an airlock in the tank maybe? i donno but the fix was free for a change.
jake 2003 Range Rover Vogue 4.4 on Gas
1961 88" 2.25 diesel - George
Gone - 1997 3.9 V8i Discovery - Burt
Post #326062 5th May 2015 9:55am
Trev18
Jake,
Thanks,
Done that, My daughter was in Liverpool on Sunday, so has to give it a run out I took her, came home and then went for her a couple of hours later.. running sweet, no temp change and no fluid gone..
Not shelling out just yet.... The garage I use has a tech call in to LR to see if they have a fix....
Trev Current Cars
Previous.
Post #326174 5th May 2015 7:57pm
The Brains Trust
Australia 2003 Range Rover HSE Td6 Adriatic Blue
Had the same problem for ages - checked and rechecked the coolant concentration, etc to no avail. I was using some aftermarket blue stuff that was supposed to be a direct replacement for the OEM coolant. In the end, I dropped that and put new OEM coolant in it and the fault went away instantly.
Post #327802 13th May 2015 8:16pm
Trev18
Thanks..
Before I change the tank.. I will drop the fluid and replace with OEM... Payday before I can do this..
Does anyone have the part No for the coolant
I will let you know the outcome
Trev Current Cars
Previous.
Post #327808 13th May 2015 9:05pm
Trev18
Found this on Topix
Engine cooling system
Petrol: Use Castrol Antifreeze SF, with one part antifreeze to one part water for protection down to -40°C (-40°F).
Diesel: Use Castrol Antifreeze NF, with one part antifreeze to one part water for protection down to -40°C (-40°F).
Trev Current Cars
Previous.
Post #327910 14th May 2015 1:52pm
duckworthparts
Site Sponsor
PDA500300 You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #327911 14th May 2015 1:55pm
Trev18
Thanks Dan,
What's the amount I would need and can you supply and give a cost if I want to do a full change out of existing
Trev Current Cars
Previous.
Post #327912 14th May 2015 1:59pm
duckworthparts
Site Sponsor
Hi Trev
you'll need just under 6 litres to do the job.
so cost for 6L delivered would be £60.00inc vat
Cheers
Dan You can paypal direct using - www.paypal.me/duckworthparts
Post #327918 14th May 2015 2:46pm
Trev18
Ok..
Does that mean it will take approx. 12 litres because you have to do the 50/50 split with Distilled water
Trev Current Cars
Previous.
Post #327935 14th May 2015 4:50pm
