![]() | Home > Maintenance & Mods (L322) > Drivetrain Oils.. Money.. |
iKushtyy Member Since: 19 Apr 2015 Location: London Posts: 94 ![]() ![]() ![]() |
So, I picked up a TDV8 3.6 a couple weeks ago now, very happy with the car, got a lot of info on it, and know what has been done and what it still needs doing. The fella I bought it off said none of the drivetrain oils have been changed, OK no worries, I know my way around a car I'll do that myself, cheers for telling us. Has to be done as it's done 86k. Went to LR parts today, enquiring what sort of money for all the oils, and personally I think they're taking the |
Ill save you a bit then |
Shell M 1375.4 is apparently the same oil but at pretty much the same price I for one wouldn't risk it |
Heh, cheers everyone..
silversurfer Member Since: 24 Oct 2013 Location: londinium Posts: 84 ![]() ![]() ![]() |
This is the gearbox oil I used although I didn't get from here . I only ever use the real Mcoy as stated by LR , so as to maintain the warranty From memory the other numbers you mentioned ring a bell. |
viper Member Since: 11 Apr 2015 Location: manchester Posts: 271 ![]() ![]() ![]() |
do you know that they charge �105 postage on everything, ive just had a quote of them for 5 litres and it comes up at that |
the gearbox oil will cost you �21 per litre and you will need 7 litres , more if you do a double drain , diff oil is about �10 a ltre and 2 litres does both , transfer box oil is �20 litre and you need 2 . not sure
