Home > Technical (L322) > Handbrake Lever |
Mal Member Since: 03 Feb 2015 Location: ne33 1lq Posts: 8 |
Morning folks,
2nd May 2015 6:12am |
Wear thick leather gloves, there's lots of sharp metal in that area |
2nd May 2015 6:49am |
Cheers, will bear that in mind, but I was looking for a bit more technical advice |
2nd May 2015 7:04am |
Changing as I have been told by garage that the cable adjuster is not working correctly, I had the handbrake shoes adjusted and handbrake is still crap.
5th May 2015 9:49am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3969 |
Before doing anything with the handbrake lever and cable have you had the rear drums off?
5th May 2015 10:01am |
Yes all that was done and the shoes adjusted up, the handbrake works but not effectively and I don't think it would go through its MOT as is |
5th May 2015 10:08am |
Unlucky.
5th May 2015 10:17am |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1696 |
Does that mean your cable is partly in the future Ash
5th May 2015 11:35am |
RRBlue Member Since: 23 Feb 2012 Location: Cambs Posts: 220 |
I replaced drum & shoes, adjusted, replaced cables. Still useless. Perhaps my adjustment mechanism on lever is knackered. Beware sharp edges and I look forward to hearing how you get on. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
5th May 2015 9:35pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16267 |
Have you tried it at different suspension heights? Due to the extreme articulation your handbrake can work well on off road height... Drop it to access height and your handbrake probably won’t hold the car at all! |
5th May 2015 10:16pm |
Have not tried that, but would have thought that the handbrake should work in all situations. No doubt I will have to replace the cables as well. |
6th May 2015 5:30am |
There is a reason they changed to an elec handbrake sir |
6th May 2015 8:42am |
Apparently that's worse most people I have spoken to reckon it always goes wrong and about a grand a pop to fix. Will stick to mechanical thank you sir |
6th May 2015 8:55am |
