![]() | Home > Maintenance & Mods (L322) > Advice about Westfalia tow bar |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3895 ![]() ![]() ![]() |
Pictures would help but it sounds like you have just got the armature with a 2" square hole in it to take tow bar itself. Geoff |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16336 ![]() ![]() ![]() |
As above... I guess you have this part fitted already sir...
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
You get the armature as a separate part.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3255 ![]() ![]() ![]() |
You say you do not have the bar that goes across. From that I think you have the factory setup which is a plate on either side to support the exhaust and provide the recovery ring out at the offside rear.
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 340 ![]() ![]() ![]() |
The above link is carrying the ',' in the URL so the link is not working: http://www.pfjones.co.uk/ Direct link to the FFRR bars: http://www.pfjones.co.uk/tow-bars/tow-bars...wbars.html regards |
Found the link to the fitting instructions: http://topix.landrover.jlrext.com/topix/co...oupId=1671
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1664 ![]() ![]() ![]() |
Don't waste your money on Westfalia, they rip everyone off just like LR playing on the OEM tie..
But if he already has the towing armature fitted it would be cheaper to just buy the drop plate for it (�95)
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35634 ![]() ![]() |
the westfalia being OE look better as well.... ... - .- -.
I got my Westfalia setup from PF Jones in Manchester for just over �300 including electrics and "agricultural" drop plate, electrics cost more for pre-2010 MY. I fitted it myself, easy enough but it is heavy. Geoff |
Only trying to help Zircon. From my reading above Reecy may not even have the armature. I'm sure Reecy will be doing his own research in addition to this forum.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
PF Jones or second hand (fleabay) are the cheapest options, I'd stick with Westfalia as cthem are OEM and will fit with no messing around. Use of a trolly jack to hold it in place when doing the bolts up, is a big help, as it is |
^ the Westfalia armature boxed up with all the packaging weighs 36.5Kg. Added to the vehicle it adds 26 Kg. Bought mine from PF Jones. Will fit it when I have summoned up the energy. |
Reecy Member Since: 02 May 2015 Location: Southport, Lancashire Posts: 56 ![]() ![]() |
Dear all,
