Home > Maintenance & Mods (L322) > Advice about Westfalia tow bar
Reecy
2003 Range Rover Vogue 4.4 V8 Santorini Black
Hi
I will be picking up my (new to me) L322 later this week-- 53 plate
There is a query though- it has part of the Westfalia tow bar fitted but not all of it- is this normal??
It looks like the main mounting brackets are fitted but not the bar that would mount the tow ball
What have I got? And how do I complete the installation?
Any ideas
Thanks in advance
Reecy
Post #326025 4th May 2015 10:11pm
supershuttle
Pictures would help but it sounds like you have just got the armature with a 2" square hole in it to take tow bar itself. Geoff
Post #326026 4th May 2015 10:21pm
As above... I guess you have this part fitted already sir...
http://www.ebay.co.uk/itm/Westfalia-Towbar...41626d8e58
Then you will need either one of the below to complete...
http://www.ebay.co.uk/itm/Westfalia-Towbar...3f2a1cac3a
http://www.ebay.co.uk/itm/Westfalia-Towbar...43c04b9076
Post #326034 4th May 2015 11:12pm
Zirconblue
You get the armature as a separate part.
You then have a choice of a drop plate towbar, a quick release swan neck towbar or a cycle carrier.
They're done like that so you can have a choice between the cheaper and more agricultural drop plate or the more expensive quick release. It's also so you can remove them for off roading. The original Range Rover and Discovery tow bars acted like a plough in deep mud and weren't easily removable.
Have a look in the boot, on the right hand side there is a lift up panel, you might well find you have a removable swan neck neatly stored in there ready for use. Smile
If how ever you find you do need to buy the drop plate or swan neck kit, you can buy them from somewhere like www.pfjones.co.uk, don't get them from Land-Rover, as they're silly money, as youve established they're just supplied by Westfalia!
Post #326037 5th May 2015 3:09am
Weegie
You say you do not have the bar that goes across. From that I think you have the factory setup which is a plate on either side to support the exhaust and provide the recovery ring out at the offside rear.
Although they have Westfalia labels on them they are not the tow bar armature. To fit a towbar they are removed nd replaced by the Westfalia armature which, as said above, gives the option of different hitches. ie. You need complete towbar setup.
There is alink in Wiki which, if you follow it through gets you to the fitting instruction which will clarify it for you.
Sorry not providing the link as I am doing this on iPad which is a PITA to copy and paste on. John
GAP iiD BT
Post #326042 5th May 2015 6:09am
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
The above link is carrying the ',' in the URL so the link is not working:
http://www.pfjones.co.uk/
Direct link to the FFRR bars:
http://www.pfjones.co.uk/tow-bars/tow-bars...wbars.html
regards
Post #326046 5th May 2015 6:53am
Weegie
Found the link to the fitting instructions: http://topix.landrover.jlrext.com/topix/co...oupId=1671
If you look at pictures 20 and 21, they show the parts to be removed and replaced by the armature.
I believe that is what you have, from your description. John
GAP iiD BT
Post #326075 5th May 2015 10:47am
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Don't waste your money on Westfalia, they rip everyone off just like LR playing on the OEM tie..
You could do worse than look at this:
http://a1-tow.com/Files/Fitting/LR732DS_B.pdf
Perfectly reasonable alternative with the same nose weight and towing capacity etc designed for the FF.
I'm having one fitted on 15th with dedicated twin electrics for £391.00. bit better than the cheapest westfalia quote of £690.00 or a local indy at £1002.00 or LR main stealer at £1200!!!!! 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #326089 5th May 2015 12:23pm
Zirconblue
But if he already has the towing armature fitted it would be cheaper to just buy the drop plate for it (£95)
Would seem crazy to remove the armature and pay for a new one to be fitted, your comment seems a bit irrelevant to the original post to be honest.
I still suspect the swan neck is probably hidden in it's compartment in the boot.
Post #326097 5th May 2015 12:50pm
the westfalia being OE look better as well.... ... - .- -.
Post #326104 5th May 2015 1:05pm
supershuttle
I got my Westfalia setup from PF Jones in Manchester for just over £300 including electrics and "agricultural" drop plate, electrics cost more for pre-2010 MY. I fitted it myself, easy enough but it is heavy. Geoff
Post #326124 5th May 2015 2:49pm
ajac8
Only trying to help Zircon. From my reading above Reecy may not even have the armature. I'm sure Reecy will be doing his own research in addition to this forum.
Not sure " seems a bit irrelevant to the original post to be honest" was justified - none taken!! 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #326129 5th May 2015 3:42pm
miggit
PF Jones or second hand (fleabay) are the cheapest options, I'd stick with Westfalia as cthem are OEM and will fit with no messing around. Use of a trolly jack to hold it in place when doing the bolts up, is a big help, as it is Censored heavy. The look on the delivery drivers face will say it all Laughing
Oh and one last thing, the drop hitch doesn't look much, be warned it's Shocked heavy Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #326173 5th May 2015 7:54pm
Weegie
^ the Westfalia armature boxed up with all the packaging weighs 36.5Kg. Added to the vehicle it adds 26 Kg. Bought mine from PF Jones. Will fit it when I have summoned up the energy. Very Happy. Delivery was free to UK. John
GAP iiD BT
Post #326176 5th May 2015 8:03pm
Reecy
Dear all,
Thanks to everyone who has replied to my query, I now understand what is fitted to my vehicle and what I have to do to get sorted out
Thanks again
Reecy
Post #326215 5th May 2015 10:31pm
