![]() | Home > Maintenance & Mods (L322) > Heater fan not working |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8509 ![]() ![]() ![]() |
Think I'd check the switch first, just because it lights up doesn't necessarily mean it's working.... Pete
Looking at the wiring diagram there is a Black/Green and Red/Green wire from the switch which switches on the motor, you could test the resistance across these wires to see if it's open circuit or put 12v and an earth down them to see if the motor works...
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
Pete, Many thanks for that info - just what I needed. |
Just been doing a bit more reading and the heater blower works from 1volt (speed1) to 8v (speed8) so check the yellow/green wire for 12v into the switch then see if the voltage to the motor varies from 1-8volts when you turn it on... |
razzer Member Since: 20 Feb 2015 Location: blackpool Posts: 54 ![]() ![]() ![]() |
hi, read your post on faulty fan motor, whats a FSR?. thanks |
Final Stage Resistor, looks a bit like a hedgehog and sits in the side of the heater, they develop a fault, flatten the battery and mess the heater up.... do a quick search on it and you will find lots of info and how to change it... Pete
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35604 ![]() ![]() |
fsr explained in our wiki, link,
