Home > Maintenance & Mods (L322) > RR lunges to right under breaking
WicklowRR
Ireland 2007 Range Rover Vogue TDV8 Java Black
Hi all, I have a problem lately when I brake hard around 60 - 70 mph , the RR slows evenly ( no pulling to left or right on the steering ) but lunges to the right . If i brake with no hands on the steering gently , it does not move to either left or right. This leads me to believe braking balance is ok ( got new pads and discs yesterday, fitted by a specialist , so not them ) Suspension or bushings ?? any thoughts ? Thanks in advance
Post #324344 25th Apr 2015 3:43pm
Sticking left side callipers would be where I would start looking
Post #324390 25th Apr 2015 7:27pm
^^^^^^ What he said..... if not that then a collapsed flexi pipe maybe, that can effect heavy braking but not light braking..... Pete
Post #324440 25th Apr 2015 10:19pm
WicklowRR
Thanks, was worried it might be suspension ,bit is rises and lowers evenly, without delay.New to RR world, so lots to learn.
Post #324442 25th Apr 2015 10:25pm
Sticking calipers is a common problem with the FFRR
Post #324449 25th Apr 2015 11:11pm
WicklowRR
Is there an easy cure ?
Post #324450 25th Apr 2015 11:14pm
New caliper, you need to check first to find what's causing the problem
Post #324454 26th Apr 2015 12:04am
Rangeyman
First check tyre pressures then have a good look at all bushes,especially anti roll.Could be shocks so look for any wet patches.Shame you cannot see your old pads as any uneven wear is a dead giveaway!
Post #324472 26th Apr 2015 9:03am
SteveMFr
Site Sponsor
Re: RR lunges to right under breaking
I am assuming that the lunging was present before the brake service? Then it should have been caught on the test drive by the tech. If the problem was not present before, then it was the tech.
Brakes are not that complex. It does not sound like a sticking caliper to me - that would manifest itself under light braking just as under hard. Sounds more like air in the system. Either way, it is not ok for a 'specialist' to do brakes and send a car back out without noticing a serious issue (and unless you are grossly exaggerating, I'd consider lunging to one side under braking to be a very serious issue). Go back and get the problem resolved.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #324809 28th Apr 2015 4:29pm
^+1... Good Advice sir Bow down
Post #324811 28th Apr 2015 5:02pm
New brakes, shouldn't do that so i would take it back and ask them to come along for a ride. If they have only done the pads and discs then they shouldn't have been at the hydraulic part at all, no need to bleed the brakes, if they changed the fluid that is another matter.
Could they have got some grease on the new discs? could cause uneven braking. Easy enough to check for a sticking caliper though, simply take it for a drive for 10 mins, park it up and leave it for 5, then come out an see if any of the discs is noticeably hotter than the rest. It tends to be the rear which stick and they don't tend to have an impact on the steering during braking, the brembos on the front are more reliable and don't tend to have as many problems. There is nothing that can't be fixed with a hammer😜😜
Post #324814 28th Apr 2015 5:10pm
Maddarren
Got same problem
Hi did you ever sort your problem I have exactly the same problem I have changed every thing new struts wheel bearings hubs steering rack track rods drum sticks and all ball joints bushes and arms discs and pads looks like I should have stated with the calipers lol
Post #394212 3rd Jul 2016 7:21am
Sandyt
I had a similar problem and it turned out to be a sticking rear calliper - it felt like the front but it was the rear
Post #394217 3rd Jul 2016 8:25am
Maddarren
Thanks for the info I will check them as well I've bought rebuild kis for the front calipers I might as well do the backs
Post #394218 3rd Jul 2016 8:38am
Maddarren
I will say with all the new parts it is driving fantastically
Post #394220 3rd Jul 2016 8:41am
