![]() | Home > Maintenance & Mods (L322) > RR lunges to right under breaking |
Sticking left side callipers would be where I would start looking |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8509 ![]() ![]() ![]() |
^^^^^^ What he said..... if not that then a collapsed flexi pipe maybe, that can effect heavy braking but not light braking..... Pete
WicklowRR Member Since: 13 Mar 2015 Location: Wicklow Posts: 13 ![]() ![]() ![]() |
Thanks, was worried it might be suspension ,bit is rises and lowers evenly, without delay.New to RR world, so lots to learn. |
Sticking calipers is a common problem with the FFRR |
Is there an easy cure ? |
New caliper, you need to check first to find what's causing the problem |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
First check tyre pressures then have a good look at all bushes,especially anti roll.Could be shocks so look for any wet patches.Shame you cannot see your old pads as any uneven wear is a dead giveaway! |
I am assuming that the lunging was present before the brake service? Then it should have been caught on the test drive by the tech. If the problem was not present before, then it was the tech. Brakes are not that complex. It does not sound like a sticking caliper to me - that would manifest itself under light braking just as under hard. Sounds more like air in the system. Either way, it is not ok for a 'specialist' to do brakes and send a car back out without noticing a serious issue (and unless you are grossly exaggerating, I'd consider lunging to one side under braking to be a very serious issue). Go back and get the problem resolved. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
^+1... Good Advice sir |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8742 ![]() ![]() ![]() |
New brakes, shouldn't do that so i would take it back and ask them to come along for a ride. If they have only done the pads and discs then they shouldn't have been at the hydraulic part at all, no need to bleed the brakes, if they changed the fluid that is another matter.
Maddarren Member Since: 03 Jul 2016 Location: Gravesend Posts: 3 ![]() ![]() |
Hi did you ever sort your problem I have exactly the same problem I have changed every thing new struts wheel bearings hubs steering rack track rods drum sticks and all ball joints bushes and arms discs and pads looks like I should have stated with the calipers lol |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2276 ![]() ![]() ![]() |
I had a similar problem and it turned out to be a sticking rear calliper - it felt like the front but it was the rear |
Thanks for the info I will check them as well I've bought rebuild kis for the front calipers I might as well do the backs |
I will say with all the new parts it is driving fantastically |
