Home > Technical (L322) > Issues after Torque Converter replacement[Verdict added] |
Shogo Member Since: 01 Jan 2015 Location: Sweden Posts: 61 |
This will be expensive I suspect..
1st Apr 2015 7:58pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
When i rebuilt my transmission i replaced the cooler and the pipes to be safe, mine is an 04 4.4.
1st Apr 2015 9:11pm |
I only changed mine so I knew the complete system was replaced. They are unlikely to fail, my concern was they may have been blocked with sludge but if you are flushing you should be fine.
2nd Apr 2015 6:32am |
Yes.. everything will be removed and cleaned. A bit worried about the snap-on connections. But they they might be able to replace just the tube and connectors on the original pipes. |
2nd Apr 2015 7:03am |
My pipes were stuck fast onto the cooler as they are like you say the push fit connections, but they may be able to shift them. i had just stripped and rebuilt the entire transmission with bearing and plates and all sorts so i thought i dont want to be back in here for a long time so changed it all, well my credit card did..........
2nd Apr 2015 7:15pm |
So Iīve gotten the car back now.
22nd Apr 2015 9:06am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8192 |
Glad it's sorted for you, thanks for posting the outcome..
22nd Apr 2015 9:57am |
Yes I hope so.
23rd Apr 2015 5:26am |
Vibration could be torque converter but it should be locked up fully at around that speed.
23rd Apr 2015 7:30pm |
Naw.. Itīs more of a driveline vibration(slower). Nothing Iīm going to worry about right now |
24th Apr 2015 9:30am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
Check your brake disc temperatures to see if they are similar all round after a short run. John
24th Apr 2015 9:55am |
Issues with vibrations seems to have been tire related as itīs gone after switching to Michelin Latitude Sports.
18th May 2015 11:58am |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3139 |
Shogo,
18th May 2015 12:24pm |
Itīs at a garage, they only replace with OEM or equivalent parts.
18th May 2015 12:38pm |
