Home > Technical (L322) > Issues after Torque Converter replacement[Verdict added]
Does your rpm needle sway up and down when going uphill on light throttle at 25-56mph ?
Stable as a rock, no movement at all
65%
 65%  [13]
Sways a little, TC rebuilt / replaced
20%
 20%  [4]
Sways a little, original TC
15%
 15%  [3]
Total Votes: 20
Shogo
Sweden 2002 Range Rover HSE 4.4 V8 Java Black
This will be expensive I suspect..
new Cooler, 2x flush including filters ?
Post #320889 1st Apr 2015 7:58pm
holidaychicken
When i rebuilt my transmission i replaced the cooler and the pipes to be safe, mine is an 04 4.4.
http://www.island-4x4.co.uk/cooler-gearbox...-7596.html
http://www.island-4x4.co.uk/cooler-pipe-ge...19736.html
http://www.island-4x4.co.uk/cooler-pipe-ge...19737.html
And the stat.
http://www.island-4x4.co.uk/thermostat-coo...-7084.html
The TC recon is a specialist job, JPAT would be my first choice, mine was done by Sussex Autoparts and has been fine for a few thousand miles
They must use the correct fluid as well - mobil LT71141 and not an alternative unless its the exact oil but rebranded
I found the best way to test the Tc was to accelerate very lightly up a slight incline and watch for the needle movement up to the 56 mph
Post #320902 1st Apr 2015 9:11pm
Shogo
The TC was replaced with a $1000 factory unit. hopefully itīs not been damaged or anything else.
The transmission fluid was still looking good.
Not sure about the oil cooler pipes, are these common problems ?
Post #320917 2nd Apr 2015 5:59am
holidaychicken
I only changed mine so I knew the complete system was replaced. They are unlikely to fail, my concern was they may have been blocked with sludge but if you are flushing you should be fine.
When I was trying to diagnose an oil leak i added a small amount of infrared Edit UV dye into my transmission fluid and even that altered the way the transmission functioned so if you have water in yours that could explain your problem.
My oil leak was the pcv hoses and cam covers
Post #320918 2nd Apr 2015 6:32am
Shogo
Yes.. everything will be removed and cleaned. A bit worried about the snap-on connections. But they they might be able to replace just the tube and connectors on the original pipes.
Post #320920 2nd Apr 2015 7:03am
holidaychicken
My pipes were stuck fast onto the cooler as they are like you say the push fit connections, but they may be able to shift them. i had just stripped and rebuilt the entire transmission with bearing and plates and all sorts so i thought i dont want to be back in here for a long time so changed it all, well my credit card did..........
i think the pipes are one piece
[/img]
Post #321028 2nd Apr 2015 7:15pm
Shogo
So Iīve gotten the car back now.
It drives ok, they replaced the cooler, thermostat and housing.
Flushed 20l of LT71141 oil thru the system aswell.
Hopefully itīll be ok for a couple of years now..
Post #323599 22nd Apr 2015 9:06am
Glad it's sorted for you, thanks for posting the outcome..
Should be fine for a long time now... Pete
Post #323609 22nd Apr 2015 9:57am
Shogo
Yes I hope so.
Drives well now .. only some vibration when going uphill at around 90-110kph .. ujoints maybe. Not to bad.
Post #323848 23rd Apr 2015 5:26am
holidaychicken
Vibration could be torque converter but it should be locked up fully at around that speed.
when i rebuilt mine and replaced the torque converter i still had a bit of vibration for a few weeks while everything settled in.
As long as they used the correct mobil ATF you should be ok
Post #324052 23rd Apr 2015 7:30pm
Shogo
Naw.. Itīs more of a driveline vibration(slower). Nothing Iīm going to worry about right now Smile
Post #324129 24th Apr 2015 9:30am
Weegie
Check your brake disc temperatures to see if they are similar all round after a short run. John
GAP iiD BT
Post #324133 24th Apr 2015 9:55am
Shogo
Issues with vibrations seems to have been tire related as itīs gone after switching to Michelin Latitude Sports.
Gearbox still working fine, but Water pump decided to eject the VC and fan into the radiator. Iīm such a happy RR owner Smile
Think ive spend about the same amount as I bought it for in repairs now Smile
Post #328434 18th May 2015 11:58am
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
Shogo,
Make sure you replace it with a Hella (OEM) one, don't use First line or others. They are pants.
Post #328441 18th May 2015 12:24pm
Shogo
Itīs at a garage, they only replace with OEM or equivalent parts.
Bad thing was that I had to leave the car 5 hrs from home and fly home. And then fly back and get the car when itīs done Smile
Regards
Per
Post #328449 18th May 2015 12:38pm
