Home > In Car Electronics (L322) > Car Parking Sensor Issue
jumbaleo
hello
i have a 2007 TDV8 Vogue.
In the last couple of weeks I have started to notice a problem with my parking sensors. For some reason the light on button on the centre console flashes and all I hear is an elongated beep and regardless of how close I am to objects I am no longer getting the proximity beeps.
Does anyone have any ideas what might be up? Is it a common fault, or is there something I could do to test the system?
I had wondered if where i had recently used polish on the body i had not removed it all, With this in mind i went around to all sensors with a microfibre to make sure it had all been removed, but the issue is still the same.
Help please? Confused
Post #323230 19th Apr 2015 3:47pm
stenh02
Scotland 2004 Range Rover Vogue 4.4 V8 Rimini Red
Sounds like a duff sensor or damage wiring. If you have a fault reader it may tell you which one is duff. If not put sensors on and listen to each sensor. As you get close to with your ear you should hear it click quietly. If they click the sensor is fine. This should help narrow down the problem. If more than one is duff maybe wiring loom. I had a problem with the rear loom on an 06.
Edit. This post has some details. http://www.fullfatrr.com/forum/topic3366.h...eck+cheque
Post #323249 19th Apr 2015 4:58pm
jumbaleo
Thanks for the information. i went around all of the sensors and none of them are clicking.
I have the car in for a service on Wednesday, so I will ask them to check it out.
Thanks for the information, it is really appreciated
j
Post #323344 20th Apr 2015 4:47pm
Or you sit in the car with the sensors activated, then get someone to put their hand in front of each sensor in turn. Being activated should make the constant beep become the usual beep beep until you reach the duff one(s) Discovery 4 HSE
Post #323346 20th Apr 2015 5:12pm
Edited due to below:
Loom seems likely and easy to replace at the back.
Last edited by Gazellio @ Prestige Cars on 21st Apr 2015 6:54am. Edited 1 time in total
Post #323348 20th Apr 2015 5:19pm
Front loom cannot just replace as its part of the main harness...
Post #323375 20th Apr 2015 7:52pm
jumbaleo
Okay, thanks everyone Very Happy diagnosed as a single front sensor. All to be sorted in a couple of days.
Post #323773 22nd Apr 2015 8:30pm
