![]() | Home > Maintenance & Mods (L322) > Filler cap retainer strap replacement |
On a slightly different slant is anybody elses tether not broken but too short to fit in to the little holder on the door ?
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Hmmmmm how strange... Shrunk in the Ausie heat maybe? |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3852 ![]() ![]() ![]() |
It's a funny story, comment not lost on me Craig but it still brings a tear to my eye (wallet) 😀 Geoff |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
Nice fix,have some 1mm black cable in the van with crimps so will have a go when I get chance. |
Right in response to you pedants out there I knocked up a Mk2 - after all who sees it except my man when he's filling the tank |
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 454 ![]() ![]() |
Just done mine.
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 ![]() ![]() ![]() |
Thanks - I have this same problem. I have sent payment for the drive belt. Any other bits I need? Or I guess this is all mentioned in the thread |
Scott,
Thanks Geoff! |
Did the mod - thanks Geoff!!
When you put your filler cap back on and twist to secure it, at the end of travel you should find “springiness” in the cap which I believe is to prevent over-tightening. The spring in question seems to be part of this mechanism.
Thanks for the info. This mod has already cost me Ł1 |
OK - spent Ł2 on proper size bolt and nut (well 10 of them), fitted the spring back in, much better now. |
Proper job! |
