Home > Maintenance & Mods (L322) > Filler cap retainer strap replacement
Page 2 of 4 <1234>
On a slightly different slant is anybody elses tether not broken but too short to fit in to the little holder on the door ?
Mine wont reach and has to swing in the breeze Sad 2008 MY Supercharged
Post #322530 14th Apr 2015 8:33am
Hmmmmm how strange... Shrunk in the Ausie heat maybe?
Post #322532 14th Apr 2015 8:40am
ebajema
Well done Geoff, thanks for the tip Wink Smile Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #322556 14th Apr 2015 11:34am
supershuttle
It's a funny story, comment not lost on me Craig but it still brings a tear to my eye (wallet) 😀 Geoff
Post #322700 15th Apr 2015 12:25pm
Rangeyman
Nice fix,have some 1mm black cable in the van with crimps so will have a go when I get chance.
Post #323139 18th Apr 2015 8:15pm
supershuttle
Right in response to you pedants out there I knocked up a Mk2 - after all who sees it except my man when he's filling the tank Very Happy.
I tried wire but the stuff I had was either too stiff or too thin - the rubber belts are perfect.
JOB DONE Thumbs Up Geoff
Post #323621 22nd Apr 2015 11:09am
bebechoon
France
Just done mine.
At first, I couldn’t see how to remove the cap cover to gain access but it all unclips reasonably easily. I used a small black nut and bolt; the nut fits nicely and is held captive under the spring in the cap cover.
An excellent idea, thanks supershuttle. Thumbs Up It's "bĂ©bĂ©choon", ackcherly, with accents. 'Steve' to my chums.
20 years ownership of Solihull products, ALL GONE NOW, sniff!
Current motor: Suzuki S-Cross 4WD auto, 1.4 petrol. Oh so reliable! 7 years now and no problems. Oh, all right then, a leaking shocker replaced under guarantee.
Previous:
TD6 HSE L322 Auto FF
2.5 TDi 4-door Classic
Disco II
And my 1st Rangie: in 1995, a 2-door VM 2.5 diesel Classic
Not to mention the Lada Niva before those. (I said not to mention it!)
Post #323896 23rd Apr 2015 8:59am
scwilson
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Epsom Green
Thanks - I have this same problem. I have sent payment for the drive belt. Any other bits I need? Or I guess this is all mentioned in the thread Smile
Post #323954 23rd Apr 2015 11:49am
supershuttle
Scott,
As you come from Dorset (the county of my birth) I have posted this morning and chucked my Mk 1 in the envelope, means you won't need crimps just the bolt or nut and bolt through the filler cap itself. Geoff
Post #324135 24th Apr 2015 10:38am
scwilson
Thanks Geoff!
Post #324138 24th Apr 2015 10:53am
scwilson
Did the mod - thanks Geoff!!
Silly question for those that have done this ... when taking the filler cap outer plastic off it reveals a rusty spring inside between two plastic ends. I had to remove this in order to fit a bolt through with a nut. I couldn't see what this spring actually does so have left it out. Any ideas?
I guess I may need to put the spring back in and use a smaller nut and bolt so it sits under the spring?
Post #324917 29th Apr 2015 10:12am
bebechoon
France
When you put your filler cap back on and twist to secure it, at the end of travel you should find “springiness” in the cap which I believe is to prevent over-tightening. The spring in question seems to be part of this mechanism.
I used a short bolt and the nut fitted in the recess under this spring. Thumbs Up It's "bĂ©bĂ©choon", ackcherly, with accents. 'Steve' to my chums.
Previous:
Disco II
Post #324918 29th Apr 2015 10:27am
scwilson
Thanks for the info. This mod has already cost me Ł1 Smile so I'll simply be careful and not over tighten I think. Otherwise I will need to splash out on a new smaller nut and bolt Laughing
Post #324921 29th Apr 2015 11:13am
scwilson
OK - spent Ł2 on proper size bolt and nut (well 10 of them), fitted the spring back in, much better now.
Post #325029 29th Apr 2015 8:33pm
bebechoon
France
Proper job! Thumbs Up It's "bĂ©bĂ©choon", ackcherly, with accents. 'Steve' to my chums.
Previous:
Disco II
Post #325032 29th Apr 2015 8:45pm
Page 2 of 4 <1234>
