Home > Maintenance & Mods (L322) > How many people have oil leaks? |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
I have same engine. I have small leaks from front of engine. The only real way to find them, is to get your hand down there and feel for them. When you find it, wipe hand and follow it upwards. The front upper timing covers leak as do the sump gasket area. It's because of the type of oil in cars these days. Synthetic oil tends not to turn to grease, and seal itself. The ageing rubber gaskets harden and let by a little. It can be a big job to replace these gasket/seals. Suggest while you are finding leaks, to park over a piece of plywood on drive to preserve your drive.
10th Apr 2015 3:12pm |
Mike.Boro Member Since: 09 Dec 2013 Location: Middlesbrough Posts: 44 |
150000 mile TD6 on a 02, none That will be the kiss of death then |
10th Apr 2015 3:26pm |
130,000 miles on my TD6 and the only moist patch is where I sit |
10th Apr 2015 3:31pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1656 |
80k on a 4.4 TDV8. no signs of leaks. (perhaps its empty ) 405 AB exec seats Baltic and Cirrus
10th Apr 2015 5:24pm |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1254 |
This being our fifth Range Rover, from a 3.5 manual carb V8 to the 4.4V8, I was always told that if a Range Rover did not leak oil then there was something seriously wrong with it!
10th Apr 2015 11:07pm |
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 |
I have the oil leaks too on my 4.4 V8 I did the vanos seloniod gaskets yesterday as they were leaking bad & thought great, I've sorted the oil leak............but NO! I guess I must have just fixed one 😳
10th Apr 2015 11:58pm |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 473 |
I prefer to think along the lines of 'it's not an oil leak, it's just a Range Rover marking its territory'. |
11th Apr 2015 7:31am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Early BMW era petrol L322's tend to leak whereas Diesels don't tend to so much sir... |
11th Apr 2015 7:56am |
Why's that Craig? |
11th Apr 2015 8:04am |
Edited now for clarity Ryen |
11th Apr 2015 8:10am |
... Although as we know... Some latter petrol models have been known to leak
11th Apr 2015 8:46am |
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 |
13th Apr 2015 11:42am |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 |
I've had leaks from my rocker covers, trans oil cooler and PCV hoses when they started to break down - sprayed fine mists of oil under the plastic cover which ran down the back of the engine bizarrely ended up looking like a leak near the front of the engine. Current Fleet:-
13th Apr 2015 6:11pm |
gg2201 Member Since: 21 Oct 2013 Location: Callington Posts: 158 |
If its the M62 BMW V8 it will be the rocker gaskets. The other half replaced mine and all seemed fine for a month or so then they started to leak again. You will find they leak from the half moons normally on the back of the engine where the camshafts are. He has done it again now and all seems fine for the minute......
13th Apr 2015 6:59pm |
