Home > Maintenance & Mods (L322) > How many people have oil leaks?
scwilson
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Epsom Green
So I've only had my Range Rover since November 2014, had both rocker cover gaskets replaced in March this year due to an oil leak but I am still getting spots on my drive 3-4 weeks after the rocker cover gaskets were replaced by an independent specialist.
So assuming it's not the rocker cover gaskets, what other things could it be? How many of you have drips from their vehicles and is it expected for a 104,500 mileage vehicle?
I have booked mine in to have the air con serviced and re-gased in a few weeks time and have asked to check for oil leaks again but I'm wondering whether I'm just going to keep going round in circles.
I lay underneath the front of the vehicle and took this photo straight up. It seems to be coming from the engine area above somewhere and running down unless this is old/excess oil from before the rocker cover gaskets were replaced ????
Post #322080 10th Apr 2015 3:49pm
johnboyairey
I have same engine. I have small leaks from front of engine. The only real way to find them, is to get your hand down there and feel for them. When you find it, wipe hand and follow it upwards. The front upper timing covers leak as do the sump gasket area. It's because of the type of oil in cars these days. Synthetic oil tends not to turn to grease, and seal itself. The ageing rubber gaskets harden and let by a little. It can be a big job to replace these gasket/seals. Suggest while you are finding leaks, to park over a piece of plywood on drive to preserve your drive.
Wiping off oil with some wd40 and cleaning around and rechecking etc. sometimes you could just need a couple of nuts tightening up, but be careful. Looking at your sump, there are two sump gaskets, lower and main. sump tray lower, and sump to block main. With a good bright torch/lamp you might be able to find its source. It's sometimes possible to seal a leak with some RTV sealant. Like shower type sealant. But for cars. Cleaned up with some solvent and applied.
Post #322085 10th Apr 2015 4:12pm
Mike.Boro
United Kingdom 2002 Range Rover Vogue Td6 Giverny Green
150000 mile TD6 on a 02, none Very Happy That will be the kiss of death then Smile
Post #322086 10th Apr 2015 4:26pm
130,000 miles on my TD6 and the only moist patch is where I sit Laughing Laughing Laughing
Post #322087 10th Apr 2015 4:31pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
80k on a 4.4 TDV8. no signs of leaks. (perhaps its empty Embarassed ) 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #322104 10th Apr 2015 6:24pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
This being our fifth Range Rover, from a 3.5 manual carb V8 to the 4.4V8, I was always told that if a Range Rover did not leak oil then there was something seriously wrong with it!
I always assumed it was part of the build quality!
Post #322134 11th Apr 2015 12:07am
PaulM
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
I have the oil leaks too on my 4.4 V8 Sad I did the vanos seloniod gaskets yesterday as they were leaking bad & thought great, I've sorted the oil leak............but NO! I guess I must have just fixed one 😳
It could be coming from my rocker cover gasket but I think it's coming from the timing chain cover. I was out today with a rag wiping & checking. 2004 RR 4.4 V8 Autobiography
Post #322136 11th Apr 2015 12:58am
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
I prefer to think along the lines of 'it's not an oil leak, it's just a Range Rover marking its territory'. Very Happy
Post #322140 11th Apr 2015 8:31am
Early BMW era petrol L322's tend to leak whereas Diesels don't tend to so much sir... Whistle Whistle Whistle
Post #322143 11th Apr 2015 8:56am
pld118
Why's that Craig?
Post #322145 11th Apr 2015 9:04am
Edited now for clarity Ryen Thumbs Up
Post #322146 11th Apr 2015 9:10am
pld118
Thumbs Up ... Although as we know... Some latter petrol models have been known to leak Embarassed
Laughing
Post #322148 11th Apr 2015 9:46am
scwilson
Smile
Ok - so process of elimination I guess. I've had both rocker cover gaskets replaced so I am hoping I can rule that out now. Possible sump gasket(s) then or other? I know it's had new breather pipes a year or so ago.
There seems to be a trend with the exception of a few that leaks are quite common Smile
Can I just confirm also, the picture I took is of the sump then? I have no idea, I'm amazed how it moves weighing in at almost 3 tonnes never mind how it works. I have little car/engine knowledge Smile
Post #322418 13th Apr 2015 12:42pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
I've had leaks from my rocker covers, trans oil cooler and PCV hoses when they started to break down - sprayed fine mists of oil under the plastic cover which ran down the back of the engine bizarrely ended up looking like a leak near the front of the engine. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #322450 13th Apr 2015 7:11pm
gg2201
If its the M62 BMW V8 it will be the rocker gaskets. The other half replaced mine and all seemed fine for a month or so then they started to leak again. You will find they leak from the half moons normally on the back of the engine where the camshafts are. He has done it again now and all seems fine for the minute......
Where the oil is leaking if you get under the car (WHEN COLD) look up from underneath at the back of the engine where the exhaust joins the manifold and shine a torch at the back of the block I almost put money on the fact you will see oil dripping from the gasket on either side which drips onto the manifold runs down the block and drips off the sump and onto the anti roll bar. You can also get the smell of oil under the bonnet as it burns off on the hot manifold.
When you fit the gaskets you need to use some kind of gasket sealant on the half moons such as hylomar or similar and plenty of it otherwise you will find that the oil will find a way past it. This is what the BMW technical guide recommends. Its also a hugely common fault with this engine along with Valley Pan Gaskets, blowing exhaust manifold, coolant leaks etc...... TBF its a miracle if it is not doing any of the above, I have a friend that works for BMW who said its a running joke that the coolant should be replaced every 5 years on them as he has never know one of the engines to hold coolant for that length of time Laughing Laughing 2011 4.4 TDV8 Autobiography
Post #322458 13th Apr 2015 7:59pm
