Home > In Car Electronics (L322) > Bluetooth ULF stopped working
Andy
Hi all.
I'm no longer getting the telephone appear on the list on the SatNav. I've tried pairing it again but I'm not getting the flashing LED on the right hand side of the screen that indicates it's in pairing mode.
Is there a fuse somewhere for it?
Thanks
Post #321925 9th Apr 2015 2:05pm
Andy
Found the problem. Pin has broken off in the ULF. Looks like a bit of corrosion. Pin 17 (red/yellow cable).
Post #321956 9th Apr 2015 4:48pm
mjdronfield
That'll be the power pin then....
I'm guessing that's a fiddly soldering job.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #321960 9th Apr 2015 5:29pm
Andy
I opened up the ULF but the socket is soldered to the pcb and has some kind of cover around it and I can't see how to get this cover off to access the base of the socket. I planned on soldering a small cable to the point on the pcb and taking the cable out the side of the ULF to the plug, bypassing the socket.
It's gonna be fiddly but I'll try it when I get some more time.
Post #321961 9th Apr 2015 5:32pm
