![]() | Home > In Car Electronics (L322) > Rear Seat Entertainment Power Supply |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 339 ![]() ![]() ![]() |
Hi Klaus,
Klaus71 Member Since: 16 Feb 2015 Location: Somerset Posts: 8 ![]() ![]() ![]() |
Will try and post a few tomorrow weather permitting. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35484 ![]() ![]() |
i'd be careful about having a permanent live as the FF's battery tends to run out of power quite quickly so with an ignition feed and the engine running you'll be sure that the FF will start. ... - .- -.
Yep, fully aware of that Stan which is why I fitted a switch in the temporary live feed. The system apparently was fed via this voltage sensitive relay automatically cutting off supply at below 11.6 volts (ish) and it is this I wish to reinstate.
http://www.fullfatrr.com/gallery/albums/us...%29%29.rar
Cheers for the link,
Pics as requested:
I think your system is made up of a bit of all sorts sir... Certainly not all factory! I would employ a good auto elec to sort it |
Entertainment & Information System Workshop Manual
