Home > In Car Electronics (L322) > Rear Seat Entertainment Power Supply |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 337 |
Hi Klaus,
5th Apr 2015 8:04pm |
Klaus71 Member Since: 16 Feb 2015 Location: Somerset Posts: 8 |
Will try and post a few tomorrow weather permitting. |
5th Apr 2015 8:25pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
i'd be careful about having a permanent live as the FF's battery tends to run out of power quite quickly so with an ignition feed and the engine running you'll be sure that the FF will start. ... - .- -.
5th Apr 2015 8:29pm |
Yep, fully aware of that Stan which is why I fitted a switch in the temporary live feed. The system apparently was fed via this voltage sensitive relay automatically cutting off supply at below 11.6 volts (ish) and it is this I wish to reinstate.
5th Apr 2015 8:35pm |
http://www.fullfatrr.com/gallery/albums/us...%29%29.rar
5th Apr 2015 8:38pm |
Cheers for the link,
5th Apr 2015 9:11pm |
Pics as requested:
6th Apr 2015 9:07am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
I think your system is made up of a bit of all sorts sir... Certainly not all factory! I would employ a good auto elec to sort it |
6th Apr 2015 9:20am |
Entertainment & Information System Workshop Manual
6th Apr 2015 10:04am |
