Home > Technical (L322) > Reduced engine performance but everything seems fine ? |
markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316 |
Also it's low on fuel at the moment around 60 miles left so don't know if that could be the cause ? Crud at the bottom of the tank ? Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
5th Apr 2015 10:03am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35267 |
i seem to remember that this kind of problem arises if you hav less than 1/4 tank of fuel, fuel pump?
5th Apr 2015 10:12am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7925 |
It could still be a dodgy cell I'd disconnect the battery for a while & see if that resolves it. Next step get the battery tested and/or read the fault codes. |
If you have a voltage meter, just check the battery voltage when running and when not running. If the battery or alternator are not in good shape, the voltage may be dropping and generate the usual random faults.
5th Apr 2015 10:21am |
Thanks guys.
5th Apr 2015 11:12am |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
Mark - I'll drop you a PM with a pointer
5th Apr 2015 2:46pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
get some petrol in it and your problem will disappear |
5th Apr 2015 6:45pm |
It's top of my to do list so fingers crossed that's all it is. Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
5th Apr 2015 7:14pm |
Filled up today. Done around 30 miles. So far so good Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
6th Apr 2015 5:15pm |
