Home > Technical (L322) > Reduced engine performance but everything seems fine ?
markcaughey
Scotland 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
out in the car tonight and bong REDUCED ENGINE PERFORMANCE. Everything is fine though and car runs just as it always does. Been a good few long runs as well so I don't suspect the battery.
Tried turning off and back on but message still apears.
also it stalled when i restarted it
now home message gone but now getting av off message on start up ??? Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #321256 4th Apr 2015 9:10pm
markcaughey
Also it's low on fuel at the moment around 60 miles left so don't know if that could be the cause ? Crud at the bottom of the tank ? Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #321290 5th Apr 2015 10:03am
i seem to remember that this kind of problem arises if you hav less than 1/4 tank of fuel, fuel pump?
see if you still have this when you fill up.. ... - .- -.
Post #321291 5th Apr 2015 10:12am
Re: Reduced engine performance but everything seems fine ?
It could still be a dodgy cell
I'd disconnect the battery for a while & see if that resolves it. Next step get the battery tested and/or read the fault codes.
Post #321292 5th Apr 2015 10:12am
ebajema
If you have a voltage meter, just check the battery voltage when running and when not running. If the battery or alternator are not in good shape, the voltage may be dropping and generate the usual random faults.
If it was the 1/4 tank issue, you would feel that it won't go as well as it should and a swift left turn would make it better (fuel going over the hump in the tank).
My best bet is voltage i.e. battery and/or alternator or resistance in the cabling/connectors. So I also suggest to check all your connections (battery, earth/ground) for looseness, damage, corrossion etc.
Hope you get it sorted soon Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #321293 5th Apr 2015 10:21am
markcaughey
Thanks guys.
What should the correct voltage be ?
I say I've been a good few long drives however before that the car did sit for a while unused and only on and off to move around in the drive. So I do kind of suspect the battery etc But then that wouldn't cause it to stall would it ? Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #321296 5th Apr 2015 11:12am
TugRR
Mark - I'll drop you a PM with a pointer
Cheers
Paul
Thumbs Up Where do you go after one of these . . . ?
Post #321309 5th Apr 2015 2:46pm
dingg1
get some Censored petrol in it and your problem will disappear
Post #321325 5th Apr 2015 6:45pm
markcaughey
It's top of my to do list so fingers crossed that's all it is. Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #321328 5th Apr 2015 7:14pm
markcaughey
Filled up today. Done around 30 miles. So far so good Thumbs Up Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #321463 6th Apr 2015 5:15pm
