Home > Technical (L322) > Front Parking Sensor Fault |
My front parking sensors seem to not be working. I'm sure it is related to the front end conversion.
17th Oct 2010 7:01pm |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 |
I have just fixed my front PDC.
17th Oct 2010 8:17pm |
Interesting, as mine has had a facelift conversion could the new sensors be incompatible with the old system/ECU? One would have hoped the conversion company would have checked this, but probably not judging by the bolt stuck in the washer tube rather than taking the time to plumb the headlight washers in! There is no ticking from the front sensors at all, where as you can definately hear the rear ones ticking, which makes me think they aren't being activated. I haven't patched into the iBus yet to run Navcoder and the associated PDC Diagnostics and may try to do that one evening this week. Dan |
17th Oct 2010 9:22pm |
OK just had a check through MICROCAT and it looks like all previous part numbers for sensors have been superseded and now come under just one part (YDB500370LML) and only come primed and require painting. Luckily LR sell a paint touch up aerosol that included colour and lacquer. I got a very good finish with my Cairns Blue aerosol.
17th Oct 2010 10:16pm |
Thanks for that, although if the new sensors wont work with the old ecu, then my concern would be that if I swap to a newer ECU then it won't work with the old rear sensors? Or possibly the rest of the car, from looking at the inputs it takes data from various other ECU's to determine speed/gear/exterior temperature etc.
17th Oct 2010 10:21pm |
There a little bit more to it than that but not much. I'll post a picture in the morning showing you the bolt locations. The new ECU part number should work as that is the only one now available and replaced the older part number within MICROCAT. Ther should be no compatibility issues at all and I really would start with replacing that from my experience... 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior |
17th Oct 2010 10:31pm |
There is on on eBay at the mo for £55, I might take a punt on it... Thanks for the info and part number. I might just try cleaning the terminals on the existing one tomorrow, or maybe do a cont' check on the sensors from the connector into the ecu. If it's open circuit then it must be cut somehwere. |
17th Oct 2010 10:41pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35338 |
DAN, my front sensors weren't working when i brought mine and the dealers mechanic traced the fault to 'chafed' wiring on the nearside sensor , he cut and re-wired and all is well... ... - .- -.
18th Oct 2010 7:57am |
Was that someone local? I'm afraid I'm going to drive into something if I dont get this fixed soon, I've not had to use my eyes for the last 2 years, I sure as hell dont want to start now. |
18th Oct 2010 8:13am |
it was the dealers relation that does all his bits and pieces and this 'relation' just happens to work at a dealership in reading... ... - .- -.
18th Oct 2010 8:16am |
https://files.me.com/stevegt/1t5p1t
18th Oct 2010 11:41am |
18th Oct 2010 11:54am |
Thank You!
18th Oct 2010 11:56am |
you seem to have the mechanical side covered steve.. ... - .- -.
18th Oct 2010 11:57am |
