Home > Technical (L322) > Front Parking Sensor Fault
rads
2005 Range Rover Vogue SE Supercharged Tonga Green
stevegt wrote:
OK just had a check through MICROCAT and it looks like all previous part numbers for sensors have been superseded and now come under just one part (YDB500370LML) and only come primed and require painting.
Dragging up an old thread, sorry chaps.
Parking sensors have gone a bit flaky in the cold weather.
I THINK the problem is at the front, and can't hear the outer sensors clicking.
There is a wide variety of prices of the sensors, on ebay the new ones YDB500370LML are £35 - £40 ish, Paddocks have the old ones (YDB100070) at £17 ish.
If stevegt, and all models now call for the new sensor, is it not also true that the older sensor should also work in 2005+ vehicles?
Thoughts appreciated.
David
Post #107119 13th Feb 2012 4:30pm
have a word with dan at duckworths...if anything he can give you the part number relating to your vin number... ... - .- -.
Post #107123 13th Feb 2012 4:46pm
rads
You miss the point.
I'm sure Dan's system will show the latest 40 quid sensor is the recommended part. I can see that myself through Microcat.
Real question is, does the earlier 17 quid sensor work?
David
Post #107128 13th Feb 2012 5:28pm
dan should be able to tell you that [hopefully] ... - .- -.
Post #107138 13th Feb 2012 5:52pm
