Home > Maintenance & Mods (L322) > Reverse lamp upgrade bulbs?
Page 14 of 22 <123 ... 131415 ... 202122>
Have you put an extra rubber ring to space it back away from the lens?
Post #321284 5th Apr 2015 9:08am
mjdronfield
Good point........ No...
I'd fitted them before you mentioned the rubber ring I think, and the bulbs just cleared - but just is not enough it would seem.
Lesson learnt.
May look at the rubber ring solution...... Or perhaps the cree in a bulb shape, see how others get on.
Thanks 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #321288 5th Apr 2015 9:34am
Post #321289 5th Apr 2015 9:43am
Scooter-s8
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
job done.
extreme light!!!!
not too sure it was an easy project....
Took a while to figure out that you need to be brave when splitting the lense!!!!
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
Post #356014 9th Nov 2015 9:10pm
miggit
It's an easy job as long as you resist the urge to stab yourself with the Stanley Knife Shocked Big Cry
Rolling with laughter Rolling with laughter Yesterday I couldn't spell Engineer... Today I are one!
Post #356030 9th Nov 2015 11:17pm
Now that the dark nights have returned I decided it was time to look at upgrading my futile reverse lights.
Read the above thread through and see that the best results seem to result from cutting the back off each of the lights or removing the lenses from the back plates and fitting smd or cob panels.
Neither of these solutions appealed to me so I set about finding an led bulb that would fit inside the reverse lights and use the existing reflectors to project the light.
As with others I found that no automotive bulbs appear to be available so i looked further afield and low and behold found what I consider the perfect bulb, a G4 led capsule. This is normally used in domestic situations but given that it runs off 12V dc and has a 5W output I thought I would try a couple.
The reverse lights are not monitored for failure so no need for canbus bulbs.
The results are truly amazing.
If it ever stops raining when it's dark I'll take some photos but in the meantime this is what I did to mount the bulbs into the existing reverse lights.
Materials.
2 G4 led 12Vdc capsules.
2 G4 sockets.
2 ¾in rubber tap washers, Black. Smile
I fitted each of the G4 sockets into a tap washer with 5mm of the socket sticking through the washer and glued them in place with a drop of superglue.
I then checked the polarity of the led bulbs to ensure that when fitted they would light.
I than fitted each of the bulbs into the sockets, first applying a drop of superglue to the head of each socket such that when the bulbs are pushed into place the bulbs are glued to the sockets and will not shake loose in the future.
I then applied superglue to the rear mounting surface of each reverse light and pushed each of the bulbs into place until the tap washer contacted the rear of the light fittings and left them until the superglue cured.
At this point I would recommend testing the light assemblies before fitting into the reverse lights.
The result is surprisingly solidly mounted bulbs.
Each of the lights are now ready to be refitted to the car and connected to the respective wires by whatever method is your preference.
For info,
The internal depth of the light fittings from rear most surface to the inside of the lenses is 40mm.
The minimum hole dia for the bulbs is 12.5mm.
The bulbs have an actual dia of 12mm not 13mm as indicated on the sellers site.
When fitted as above the bulb and socket assemblies each project into the fittings by 32mm ie 8mm from the inner lens surface.
This ensures the the leds project light onto the reflectors.
The colour temperature of the bulbs is 5500-6000K so the light is very bright white.
I appreciate that by gluing the bulbs and tap washers into place replacement of a failed bulb would involve cutting the tap washer from the rear of the light fitting and a new G4 socket but given this is hopefully unlikely and the nominal cost of the bits I am prepared to do this.
Below are a few photos I took which I think are self explanatory.
These are the bulbs I used,
http://www.ebay.co.uk/itm/391135621046?_tr...EBIDX%3AIT
and these the G4 sockets,
http://www.ebay.co.uk/itm/361184236414?_tr...EBIDX%3AIT
Post #359398 28th Nov 2015 7:02pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
@NDFI - great post - on my list TO DO.
Many thanks for sharing. Very Happy Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #359404 28th Nov 2015 7:52pm
miggit
FYI splitting the reflector from the lens is not that difficult, and I have found that as long as the lights are at room temp or higher they will split with the minimum of fuss. You just need to find the join between the clear and coloured and gently cut along the join, with Stanley, if you start with the long sides first, you'll soon find that the "quality" weld ( Rolling with laughter ) will give out and you'll be in. There are bits that you can't get the knife in to but I found that once you have the main welds split the rest just waves it's hand's up and gives up.......... no wonder the bloody things leak Shocked
The main advantages with splitting the lenses are, one, you can get multiple panels in there, I have 2 x 6 watt cob panels in mine, and two, you do not rely on the slivered reflector to dissipate the light..... so if your lights have been letting the water in (unheard of Shocked ) the performance is not effected, and it gives you a chance to take a scrubbing brush and soapy water to the inside to make them less green Thumbs Up
NDF I watch this space with interest for "after" shots Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #359432 28th Nov 2015 10:01pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
post install night pics!!! Very Happy
I like this idea versus the LED boards 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #359932 1st Dec 2015 2:11pm
^ As soon as I get a dry night I will. Been b Censored y raining since I did them. Thumbs Up Very Happy
Post #359939 1st Dec 2015 2:44pm
miggit
This thread has night pics of an install that I did for a pal http://www.fullfatrr.com/forum/topic34595.html
The major advantage with the flat panels are you can get multiple units in a lamp, Pete managed to get 4 in each of his, assuming that they were 6w, he'd have been pushing 24 w led that's about 180 w filament output and he had x2 Shocked
Those pics are of 2 x 6 w led which are putting out the equivalent of 90 w per side, which is why you can actually see behind in the dark Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #360040 1st Dec 2015 11:35pm
As requested pictures of the lighting effect of my recent re-lamped reverse lights.
Bit of a murky night but at least it's not raining.
More than adequate for confident reversing without blinding other road users. Thumbs Up
Post #360146 2nd Dec 2015 6:52pm
horse86
very nice...so brighter than stock? That's with those G4 capsule bulbs? Are they slightly different color IRL? The one looks a little greener?
I've seen some that come is different wattage. I think I saw some that go up to 2w..what is the wattage on yours?
Did you cut off the OEM socket base and solder the leads from the G4 connector to the stock wiring? 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #360152 2nd Dec 2015 7:35pm
Definitely brighter than original stock lights.
I used a G4 5W capsule bulb in each reverse light.
I chose to cut the original bulb holders off the wiring and simply soldered the new wires to them.
It's highly unlikely I would ever revert to original but if I did I think I would simply be inclined to buy new reverse lights and replace the present ones. New lights come with a wiring tail about 100mm long with a plug on the end which plugs into the wiring harness so the "cut" ends are then scrap anyway.
The "green" picture shows the view from the reverse camera displayed on the car screen. I'm not sure why it has a green tinge, must be something to do with the camera output and photographing the screen.
Post #360156 2nd Dec 2015 7:50pm
nice job dave Thumbs Up ... - .- -.
Post #360158 2nd Dec 2015 7:58pm
