Home > Technical (L322) > New owner with a load of problems to diagnose
PaulM
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
After checking & clearing codes with hex helping me out with the fault reading, we got two main faults. One was the gearbox selector switch, which is what triggers the "Trans fail safe prog" when you go to reverse/park to drive etc. The other code given was "ambient temp sensor" & the car reads -40c outside.
Also on the way back it stuck in 2nd gear, manual mode would not shift it either. After pulling over for 5 mins & restarting again it was ok but never chucked up a fault code. 2004 RR 4.4 V8 Autobiography
Post #318755 20th Mar 2015 7:38am
PaulM
Ok so far seems I need to get the inhibitor switch for the gearbox as it just keeps going into "trans fail safe" everytime I go from park. I then put it in neutral & turn it off & on, then its fine. Also the oil leak is coming from both vanos seloniod gaskets. So they are my first two jobs. 2004 RR 4.4 V8 Autobiography
Post #320690 31st Mar 2015 5:57pm
jdig
United Kingdom 2005 Range Rover HSE Td6 Zambezi Silver
Was the car ever towed?
Check the fuses in the glovesbox
Is there one in slot 37? Bottom row
Post #320725 31st Mar 2015 9:35pm
PaulM
I've never towed it, Im sure I've read about this fuse 37. What's it's all about? 2004 RR 4.4 V8 Autobiography
Post #320729 31st Mar 2015 10:52pm
jdig
I had it on mine it's supposed to be removed
After the car is towed if theres a bit of movement you get the transferbox
Neutral message come I had this at a car wash & couldn't move lol
Removed the fuse & all has been fine since mine was bought from auction so was
Obviously towed there Thumbs Up
Post #320735 1st Apr 2015 6:54am
PaulM
Yes I had that message, I'll check it out later after work. 2004 RR 4.4 V8 Autobiography
Post #320743 1st Apr 2015 7:47am
PaulM
No fuse in slot 37. 2004 RR 4.4 V8 Autobiography
Post #320851 1st Apr 2015 5:10pm
