Home > Technical (L322) > New owner with a load of problems to diagnose |
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 |
Hi guys, I'm a new FFRR owner since yesterday.
8th Mar 2015 2:30pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7815 |
Hi and welcome.
8th Mar 2015 3:41pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Welcome to the cruel world of FFRR ownership!
8th Mar 2015 3:49pm |
^^^^ see what I mean (ECU chains)
8th Mar 2015 5:13pm |
8th Mar 2015 5:32pm |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 |
The engine oil leaks are either the rocker cover gaskets or the PCV hoses - lift the plastic engine cover off and towards the back there are some rubber pipes running across the top of the engine - these deterioate and turn to mashed sponge - if they are gone then you will be leaking oil down the back of the engine as it will be a fine misty spray of warm oil. Current Fleet:-
9th Mar 2015 9:43am |
Ok a little update on the RR, I has a good look at it Sunday & you can see it's had work done as the front engine cover has been removed. The problem is the cowboy that did the work must have used the old gasket as there is sealer all round the gasket, that looks to be one place the oil is leaking from. The other is one of the breather pipes on the top at the back of the engine wasn't even connected! 2004 RR 4.4 V8 Autobiography |
11th Mar 2015 6:27pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8284 |
That pipe at the back could have blown off because the PCV valve is bunged up... this causes crankcase pressure and lots of leaks, there is a how to in the Wiki..... Pete
11th Mar 2015 6:32pm |
hex Member Since: 22 Jun 2014 Location: coventry Posts: 108 |
Paul what part of Warwickshire you in may be able to help with the fault reading and clearing . |
11th Mar 2015 10:10pm |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
hi
11th Mar 2015 10:42pm |
I'm in Coventry hex.
12th Mar 2015 11:21pm |
Me to and the odd thing is I am paulm as well lol
14th Mar 2015 8:56pm |
babagee Member Since: 15 Feb 2015 Location: Somewhere between St. Helens & Kazakhstan Posts: 142 |
This is what I love about these forums - the collective knowledge and the willingness to help fellow owners
14th Mar 2015 9:34pm |
Yes Ian, that's what I love about these forums too. The sense of community & willingness to help, Land Rover forums are top of the list for this too
15th Mar 2015 9:33am |
