Home > Off Topic - Photos and Video > The aeroplane spotters thread
Page 20 of 20 <123 ... 181920
Birdbrain
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Thanks Kurt.
Just assumed it was 16. It made hell of a racket when they fired it up. I think the owner uses it for air displays.
Post #320638 31st Mar 2015 12:08pm
Rotary aero engines died out during the first world war. They are not to be confused with w-a-n-k-e-l engines (hyphons needed or the censorship nazi turns it into a Censored ). They look like normal radial engines but instead of the crank turning the prop, the crank is bolted to the aircraft and the whole engine rotates around the crank. The prop is bolted to the engine.
It sounds crazy, and it is, but that's how many engines worked. Here you can see one starting.
There are no 16 cylinder radial engines. Each row of a radial engine must have an odd number of cylinders, otherwise the firing order doesn't work, so while there are 14 cylinder two row radials and 18 cylinder two row radials, there are no 16.
Also, it was easy to count the number of cylinders in the picture you posted, and it didn't look like that size/age of aircraft would have an 18 cylinder engine.
Post #320648 31st Mar 2015 12:52pm
DMRR wrote:
I'd like one of these : http://en.wikipedia.org/wiki/North_American_X-15
A truly amazing air/space craft. I remember reading about it as a kid and it was like a fantasy world. 4500mph!
I saw it in the flesh at the Smithsonian 9 years ago.
Looks very wierd from the back.
Post #320704 31st Mar 2015 7:56pm
Air Canada described this as an 'incident upon landing'. Whistle
Post #320721 31st Mar 2015 9:08pm
Refuelling a Stealth Bomber mid-flight
Click
Post #321401 6th Apr 2015 8:44am
Did you know that the guys up front were flying accross the atlantic relying on an iPad App....... Shocked
http://www.bbc.co.uk/news/technology-32513066
Post #325063 30th Apr 2015 7:27am
RR2008HSE
AND they had to taxi back to the terminal to use the wifi! Laughing I guess even the pilots couldn't afford the in-flight wifi charges. Mr. Green
Post #325585 2nd May 2015 8:00pm
