Home > General > exhausts and tow bar
m10rng
United Kingdom 2004 Range Rover HSE Td6 Java Black
thinking of changing my exhausts to get a slight rumble or something along these lines on my td6, any advice??????
also taking off my tow bar this weekend any thing to watch out for???
Post #31907 15th Oct 2010 1:47pm
nbunney
Doesn't look like a LR towbar so carn't comment.
What you doing with the towbar?
Post #31929 15th Oct 2010 6:13pm
I have a removable towbar but the sod is seized in. It took a fair amount of heating just to get the pin out, so I think I will have to take the bar off the vehicle to get the end out Big Cry
Post #31939 15th Oct 2010 7:43pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
John, it's a quite large armature that it's mounted into, you may need a helper with the weight of it, also you can download all the accessory fitting instructions from the Land Rover website as PDF documents - I assume that taking it off will be the backwards of putting it on!
All owners manuals and accessory instructions can be downloaded from here
http://www.ownerinfo.landrover.com/extfree2viewlrprod/index.jsp
In the lower section you have to scroll down to find the accessories instructions
For TSB's and recall info you have to subscribe, but then you get 24 hours unlimited downloading for your money 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #31941 15th Oct 2010 7:53pm
Thanks for the link Tim, it isn't a difficult job to remove the towbar
Post #31945 15th Oct 2010 8:08pm
Tim in Scotland
But the removable tow hook weighs about 15kgs! 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #31947 15th Oct 2010 8:14pm
Nothing compared to dropping a rear diff on the S-Class a few weeks ago Shocked
Post #31953 15th Oct 2010 8:28pm
Tim in Scotland
You mean Mercs fail ........... Shocked 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #31957 15th Oct 2010 8:32pm
Almost as bad as RR Sad
Post #31961 15th Oct 2010 8:47pm
