![]() | Home > Maintenance & Mods (L322) > Pray for me please |
87RJD Member Since: 01 Dec 2013 Location: Wokingham Posts: 103 ![]() ![]() ![]() |
Hi
HalifaxMark Member Since: 03 Feb 2015 Location: Halifax and / or Civray France Posts: 14 ![]() ![]() ![]() |
Thanks for the reply, it's only covered 66k.
Garyfax Member Since: 02 Feb 2015 Location: Halifax Posts: 124 ![]() ![]() ![]() |
Good luck mate. |
I'd be inclined to agree, the wheels are fitted to hubs albeit through bearings, why would a diff issue cause wheel wobble. Be interesting to hear the outcome, hopefully not too expensive. ![]() |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Never heard of the diff causing a wheel wobble, usual culprits
marky777 Member Since: 05 Mar 2015 Location: Christchurch Posts: 141 ![]() ![]() ![]() |
Good luck fella let's hope it turns out to be a cheap fix so you can leave that kidney attached to its rightful owner |
Update on my tale of woe. Brian at Green Oval has told me everything else on the FF is fine and dandy, disks fine and been through the suspension with a fine toothed comb. only other problem is that my rear washer doesn't work - yippee.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Hmm, I once contacted Green Oval via their webpage for a quote on work and they never even replied so I went elsewhere. Discovery 4 HSE
Ziggy Member Since: 26 Dec 2011 Location: West midlands UK /sydney AU Posts: 265 ![]() ![]() |
Cobber the diff is only a crown wheel and a pinion the pinion gears put the driving force into the crown wheel
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Mmm...but If the E-Diff motor has failed ( as mine did) it could lock the rear axle which could cause a judder on cornering, but I felt that on mine coming from the rear as a vibration. Cost about £400 to sort that specific issue on mine. GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
when I am driving around town etc, I can't feel a thing, 65 mph and it drives like a dream and no noise, but 70 and gentle corners it really vibrates strongly, incredibly strongly, through the steering wheel.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35646 ![]() ![]() |
have you checked the tyres for balance, wheel alignment and front bushes.. ... - .- -.
Having broken plenty of diffs too .... not sure the symptoms match the solution given. I had full lockers on my Disco and all you get if you leave them all on is tyres scrub and a resistance to tight cornering.
as soon as the wobble started I changed all 4 tyres and had the balance checked twice after. I have read on here that it can be challenging to get them right first time.
