Home > In Car Electronics (L322) > Digital TV Upgrade
Page 8 of 18 <123 ... 789 ... 161718>
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Crumbles Argyll's roads must be busier than I thought if you get TMC reports up there.......................... they are rare enough down in the Central Belt. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #31693 14th Oct 2010 9:26am
Tim your quite right but I just drove to Wales and back and couldn't understand why it didn't work . 2008 MY Supercharged
Post #31708 14th Oct 2010 11:59am
Tim in Scotland
I bet it wasn't giving that the A83 was closed yet again at Port Ann this morning for another truck/ car off the road.................................... Strathclyde Police just seem to shut the whole road at Inveraray and make anybody going beyond Loch Gair take the long route via Oban to Lochgilhead (it's very useful to know the forest trails though as if you know the route from the Glashan Dam through to the Lochgilhead Golf Club you cn avoid the blackspot when the road is closed, helps to have a 4x4 too because the trails are a bit rough but still passable in a BMW 3 series if you don't drive like 3 series drivers normally drive Whistle ) 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #31713 14th Oct 2010 12:48pm
BobbyDazzler007
2008 Range Rover Vogue SE TDV8 Buckingham Blue
Hi Wiggs. Finally got round to fitting the digital tuner I got from you, and it works a treat.
If any one's interested, RCA Audio in Cheadle near Stockport fitted it for me for �50 - couldnt be bothered doing it myself, and it took them hours! Ha!
Cheers
Post #31718 14th Oct 2010 1:43pm
Hackweg
England 2005 Range Rover Vogue Td6 Java Black
Well there is a bit , I just spent a couple of months wondering why my TMC didn't work until I put all my plugs back in
So axle, does that mean with the D4 TV box that TMC will not work unless you go back to the original TV box ?
Post #31768 14th Oct 2010 7:15pm
Herdwick
I did the same conversion a couple of months ago, using the tuner from Wiggs, TMC still works fine for me.
Great instructions are posted earlier on here.
Post #31823 15th Oct 2010 8:08am
No I'm not saying that the new TV box won't let the TMC work its just that in my hurry to dismantle all the boxes and cradles to fit my new TV I didn't bother to label the cables , we don't get TMC hear so for a few months I wasn't sure until I drove a good distance through Englandsestershire to figure out it wasn't working and in fact the arial pug was stuck round the back of another box. 2008 MY Supercharged
Post #31824 15th Oct 2010 8:34am
Andpopse
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Hi Wiggs,
I've PM'd you, and I'm hoping you can supply me a TV Tuner. I look forward to hearing from you.
Many Thanks
Andy
Post #32062 16th Oct 2010 8:33pm
wiggs
Reply'd Thumbs Up
Post #32085 17th Oct 2010 11:24am
Andpopse
Thats Great, Please PM details of how and where to pay you.
Thanks
Andy
Post #32127 17th Oct 2010 8:21pm
Andpopse
Tuner arrived....... What great speed of delivery !
I haven't yet looked, but is it simply a case of unplug the analogue and plug in the new one. Then work out a permenant fixing/bracket ?
Thanks
Andy
Post #32475 19th Oct 2010 8:49pm
wiggs
Yep ..4 connectors ...just unplug.. then connect to the new tuner . If you dont have RSE ( rear seat entertainment ) you can slot the new tuner down in front of the old one .
Go to TV and press auto ..it will then find all the channels available .
Then when you have time remove the panel and swap the tuner over ..only the top 2 bolts fit as the new tuner is a differnet size ..but its solid and wont go anywere .
Post #32477 19th Oct 2010 9:26pm
Andpopse
Wiggs,
One last question ..........
Do you disconnect the earth of the battery before swapping the tuner?
Regards
Andy
Post #32519 20th Oct 2010 9:41am
wiggs
No
Just take the key out and wait 2 mins
Post #32521 20th Oct 2010 9:46am
fin
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
Wiggs i'm after one of these and can collect i've sent you a PM for some contact details
Regards
Post #32535 20th Oct 2010 12:51pm
