![]() | Home > Maintenance & Mods (L322) > [HELP] Odd coolant drops... then they're gone + other leak! |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Hi gang, could do with some help really. A very odd thing happens, here the deal:
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
as it gets colder the pipes/seals contract and you get leaks...warm them up and they expand and no leaks..[maybe |
could be any of the connections..i'd tighten every hose that was replaced by your indy.. ... - .- -.
Original post edited with more pictures.
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
At the back of the engine there are a few hoses. Also the coolant manifold which connects the left and right banks. It has a hose coming from it thats known to fail. The manifold has to aluminium tubes linking to the water pump and they only have push fit o rings. If your indy has replaced all existing hoses the pressure will look for the weak point. I doubt they would have replaced these o rings. Also the valley pan is a weak point that might be vulnerable now everything is new and fresh? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Thanks Rob, any chance you'd have photos showing me the said parts (or threads or schematics?)
In your original post 2nd link is mine. The 6th pic shows the 2 pipes running front to back and the manifold at the back with the 2 known weak hoses. Also the valley pan cover is seen with coolant staining down the left hand side. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
Mine has done a similar thing on more than one occasion, I'm waiting for it to get worse so I can sort it...
Also i think you have the wrong cap. You shouod have a 200 rated one. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
The early 2002-2003 cars had a 140 cap, mine had a 200 when I got it but Dan checked and it should have a 140.... Pete
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
This was my leak a couple of years ago.. The hose isn't standard bore, it's a reduction. New part £7, apparently fail around the 10 year mark, mine was 12 years when it failed. |
Thank you all, especially steptoe as I think you may have found the problem, spot on!
Here is the said potential faulty hose/connecting pipe, ordered already :
That hose hasn't been changed! |
