Home > Wheels & Tyres > Wheel alignment / tracking.. How hard can it be?? |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 |
Have you had your rear suspension bushes renewed. (Could now need adjustment) If not, they might need renewing, as rear edge wear is a sign, search here for a wiki, it will show you what is involved. It could be adjusted on a ramp, and then be out as soon as it's moving, because of play. If you find a garage that will do it, ask them to check, just lift a wheel one inch off floor, perhaps with a trolley jack under the wishbone, and using a longish crowbar as the lever, rock wheel from underneath up and down, with a hand on rear bush, and it might have play. |
7th Mar 2015 6:10pm |
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 |
What part of Essex are you? How far are you from Chingford
8th Mar 2015 8:10am |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 |
I have used Skid Marques in Brentwood for my BMW did s good job on that. There is a difference between knowing your sh!t and knowing you're sh!t
8th Mar 2015 10:59am |
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 |
Cheers guys, booked in for rear bushes this week and then will give these places a try with a hunter machine |
24th Mar 2015 11:07am |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 226 |
If you aren't too far from Ipswich, you could try Ipswich Accident Repair centre, the guys there are pretty good and do alignment for a lot of races teams. |
24th Mar 2015 6:49pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
I had my RR aligned 3 times at different places before they finally got it right there's a lot of muppets out there claiming they know what they are doing Present :2008 TDV8 HSE
24th Mar 2015 7:13pm |
