Home > Wheels & Tyres > Wheel alignment / tracking.. How hard can it be??
JPS
2005 Range Rover Autobiography Td6 Zambezi Silver
Hi, have a fairly new set of at grabber tyres fitted to my vogue and noticed yesterday that the n/s/r is wearing out on the outside edge quite badly, the other 3 tyres seem ok though.
Thought I would go and get my tracking checked this morning but after going to two garages and wasting most of the morning I'm non the wiser.
First garage I went to (A1 auto centre) had the car nearly an hour whilst I waited to then tell me they couldn't do the tracking because the settings weren't listed on there machine??? And said to go next door to quick fit as they had the latest machine.
So off I went next door, guy books it in and puts it on the ramp..come back half hour later and says it's too complicated and can't get to the front or rear to adjust and said my best bet would be to go to the main dealer.
Seriously is that the case? Surly it's a pretty basic job I'm asking? Oh and to top it off he got in my car without so much as even putting a seat cover or gloves on and his hands/overalls were filthy. What is wrong with these people.
Post #316713 7th Mar 2015 11:36am
johnboyairey
Have you had your rear suspension bushes renewed. (Could now need adjustment) If not, they might need renewing, as rear edge wear is a sign, search here for a wiki, it will show you what is involved. It could be adjusted on a ramp, and then be out as soon as it's moving, because of play. If you find a garage that will do it, ask them to check, just lift a wheel one inch off floor, perhaps with a trolley jack under the wishbone, and using a longish crowbar as the lever, rock wheel from underneath up and down, with a hand on rear bush, and it might have play.
Post #316745 7th Mar 2015 6:10pm
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
What part of Essex are you? How far are you from Chingford
Place down the road has brand new Hunter set up
Did 4 wheel alignment on mine no problem. So I guess he knows his way around a FF ?
That was 15 months ago, had no issues Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #316825 8th Mar 2015 8:10am
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
I have used Skid Marques in Brentwood for my BMW did s good job on that. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #316855 8th Mar 2015 10:59am
JPS
Cheers guys, booked in for rear bushes this week and then will give these places a try with a hunter machine Thumbs Up
Post #319396 24th Mar 2015 11:07am
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
If you aren't too far from Ipswich, you could try Ipswich Accident Repair centre, the guys there are pretty good and do alignment for a lot of races teams.
Post #319473 24th Mar 2015 6:49pm
Googsy
I had my RR aligned 3 times at different places before they finally got it right there's a lot of muppets out there claiming they know what they are doing Evil or Very Mad Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #319477 24th Mar 2015 7:13pm
