![]() | Home > In Car Electronics (L322) > My Reverse Camera Install |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 ![]() ![]() |
I�ve finally got my reverse camera fitted and working and here�s how I done mine. Though it may help someone else in the future. Ive paid under 40 pound to get this up and running. Remember that you need a NTSC camera, just found a 170 degree camera in Birmingham for 11quid.
Im no good at soildering so I used these for the joint connectons on the relay
This was the wiring harness with AV input for the camera to plug into, I bought this off a guy on here a while back
First part of the install was to disconnect the plug on the TV tuner and plug the new harness in
So it was the white plug out and plug in the connection harness between them Then you have to add a wire to the blue plug pin 17
More info on this from this site http://www.roverupgrades.com/Range_Rover_TV_installation.html Then you need to decide where to fit your camera, I went with what I believe to be a stock location and worked out where I wanted it prior
I then checked the double skin and drilled the holes etc after my technically approach to marking the area where I wanted to fit the camera
Heres the camera fitted initially I used the bolts as washers till I grinded down some smaller self tappers, I don�t this as I didn�t want to come through the paint work or dent the spoiler from underneath with the screws. Camera fitted
I then run the cable along and hot glue gunned the cable down and run the cable through the grommet into the inside of the car and then through the next grommet into the car its self, I couldn�t get the input cable through the grommet because of its size so I cut it off and reconnected it once the cable was through, I then run the cables down to the TV tuner area. The next job was tapping the reverse lights which was a white and yellow lead, scotch locked on the cable and run this back to the tv tuner area. Then come the fun bit a relay to allow the ground to open and close taking control of the TV screen using the earthed wire on pin 17. I used this wiring diagram form a BMW site to get it wired up ![]() Relay wired up
I don�t like the fact the camera is on the ignition switch and will later try tapping the camera off the other reverse light, the reverse light on its own isn�t powerful enough to activate the camera and the relay hence you need to connect a ignition cable to the camera This was the best image from the screen I could get this morning, ive since found out this is a 150 degree camera and I�ve now just order a 170 degree camera which will give me more scope.
Hope this helps someone when they come to fitting the camera Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Last edited by cliffy on 11th Apr 2014 5:25pm. Edited 1 time in total |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35628 ![]() ![]() |
nice job, put in the wiki.. ... - .- -.
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2290 ![]() ![]() ![]() |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
Thanks guys I just hope it helps |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Hi, I have just brought a 004 L322 and would like to fit a reversing camera, to save the bumper when hitching up trailers. Having read your post I'm now gutted that I purchased a 5" monitor for the camera I also brought. I was under the impression that you needed fit a DVT up grade to achieve the camera input |
I have now fitted my camera and WOW!!!
Zambezi Member Since: 07 Feb 2015 Location: Bury St Edmunds, Suffolk Posts: 67 ![]() ![]() ![]() |
Found this thread and it's exactly what I was looking for as I also tow frequently and this would make lining the towing hitch up very easy.
Hi, I've not used a wireless camera for a long time, they are prone to electrical interference, and could cause the picture to breakup at the worst moment. Also to enable the use of wireless you will need to get a power feed out the tailgate to the camera, in all honesty I would use a hard wired one.
Something like this would do the job
Thanks. I appreciate your advice. Have you managed to clear the bulb warning issue caused by the led ?
Fish Member Since: 30 Aug 2014 Location: Bolton Posts: 301 ![]() ![]() ![]() |
I am thinking of adding a second camera for hitching up to the tin tent and thought about a wireless one near the tow bar wired into the tow sockets for power. I can use the factory one for normal reversing, although I think it could do with an upgrade, and connect the second one to my phone when hitching up. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3891 ![]() ![]() ![]() |
Fish, I would have thought the Venture Cam is pretty good for that sort of thing although not having ever had a caravan i'm not qualified to comment - but I don't let that stop me |
interesting thread here Fish,
