Home > In Car Electronics (L322) > TFT Brightness
Page 2 of 3 <123>
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Ive noticed my screen will fluctuate with brightness for example it gets dim if it is extremely cold outside.
Post #315776 2nd Mar 2015 8:58pm
thats normal...the lcd crystals get cold and also they dont get enough voltage so the screen doesnt function properly ....a vehicle re-start will sort it.. ... - .- -.
Post #315779 2nd Mar 2015 9:02pm
Andy B
Hi Chillb, glad I am not alone with this problem Very Happy Today it was fine, it was dark when I drove home from the station and the TFT was dimmed. I don't think it is related to the headlight settings, there must be something elsewhere in the car that monitors light sensitivity. Random RR fault.....no surely not Shocked
Cheers,
Andy SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #315782 2nd Mar 2015 9:07pm
horse86
Yea they actually "warm-up" after a little while and they are back to normal so I typically don't bother with it.
Post #315785 2nd Mar 2015 9:11pm
Andy B
I blame the English weather then! Laughing SDV8 AB MY 2019
Post #315786 2nd Mar 2015 9:13pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Mine has a light sensor top right above the phone button. If I cover it up it dims the display, but only if the headlights are on. My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #315796 2nd Mar 2015 11:00pm
Andy B
Cheers Hoppy, I'll check that out. TFT seems to back to normal now and dimming when it should Very Happy SDV8 AB MY 2019
Post #315857 3rd Mar 2015 8:27am
...or, go to a car window tinter and get an offcut and place over problem screen........sorted. Mr. Green ... - .- -.
Post #315860 3rd Mar 2015 8:32am
Andy B
You could be on to something there Stan. Moderators Mods Ltd Laughing Thumbs Up SDV8 AB MY 2019
Post #315885 3rd Mar 2015 10:09am
Laughing Thumbs Up ... - .- -.
Post #315911 3rd Mar 2015 12:43pm
Chillb
United Kingdom 2008 Range Rover Vogue TDV8 Rimini Red
Checked and mine, 08, does not have a sensor on or near the screen, only the dash lights dim from the wheel. There is in the settings menu a screen brightness and colour change but surely this is cannot be the only way to access while driving. I remember of my old 03 model, the screen and dash lights dimmed from the wheel by the headlights.
Anyone else with an 08 where the screen does not dim with the wheel Question Porsche 993 Targa, Buick Skylark Convertable 1968
Post #315919 3rd Mar 2015 1:10pm
Mike, yours does have a sensor ...its number 12 on the diagram..
Post #315929 3rd Mar 2015 1:30pm
Chillb
Oh Whistle
Did see that but thought it was an indication light of some sort. So without digging a bigger hole, should it automatically dim at night or should I be able to control in addition by the use of the 'dimmer wheel' Porsche 993 Targa, Buick Skylark Convertable 1968
Post #315958 3rd Mar 2015 3:42pm
your dimmer wheel should dim it slightly.[as well as your speedo/rev dash bit btw] ... - .- -.
Post #315974 3rd Mar 2015 5:33pm
Stan is right on the money Thumbs Up
The D3 uses the same screen setup (believe it or not) and cutting one wire changes the D3 screen into L322 mode! BUT... Albeit quite dull as the D3 does NOT have the light sensor found in a RR!
So, i would assume your screen if malfunctioning if it is NOT dimming with the ambient light around the cockpit...
Post #315997 3rd Mar 2015 7:04pm
Page 2 of 3 <123>
