Home > Technical (L322) > Suspension fault
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Suspension fault
Let's hope this is not the start of bad times! New to me my 2007 VSE, 3.6, went to go to work tonight and I get suspension fault! Stayed on the screen for a few seconds then disappeared! Switched on and off but it reappeared!
Got home tonight and switched off to hear a lot of clicking behind the dash!
Also got the message transmission fault, traction reduced!!
Car will now not start!!
Gutted doesn't cover it!!
Any pointers?? Shall call the garage in the morning
David 2014 vogue se
Post #314885 25th Feb 2015 10:10pm
Sounds like battery problems starting there. Put it on charge overnight to see how it is in the morning.
If your battery and alternator haven't been replaced yet I would have them looked at closely as the 07 alternators were a bit prone to failure. There is nothing that can't be fixed with a hammer😜😜
Post #314886 25th Feb 2015 10:13pm
chefkenmore
Methinks battery too! Thank you, alternator suspect? What would you replace it with?? So want this car to be right! Absolute dream to drive!!
David 2014 vogue se
Post #314891 25th Feb 2015 10:32pm
Rovertech
United States
Not sure if it's a fit on the 3.6, but Bosch has a 2 year roadside assistance warranty here in the states. That's what I replace all my personal vehicles alternators with.
Post #314976 26th Feb 2015 2:03pm
chefkenmore
Garage been out with a new battery! Car started fine but no input to battery!! So new alternator tomorrow ! Thank goodness for warranty !!
David
Thanks for the swift replies 2014 vogue se
Post #315018 26th Feb 2015 7:10pm
The replacement is a denso unit. There aren't many other options. I think Lucas do one but I don't think they make them any more just re manufacture rotating components like starters and alternators.
I reckon you will be sorted once done. If it's under warranty then you've done well Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #315019 26th Feb 2015 7:23pm
