Home > Maintenance & Mods (L322) > 2010/2012 facelift conversion - my step by step guide
Page 3 of 12 <123 4 ... 101112>
Topvar
2007 differences
Great post
Have just done my 2007.
Few comments to add
No cutting of wings required - just change the brackets - can do this with out removing wings
You will need to run a +ve to the headlights and use relays to control the indicators and sidelight - interfaces available on fleabay
Buy the genuine washer hose set just £7
Washer pump is fine on the 2007 model
Use the genuine harness for PDC and splice into car loom
Overall ...... Very easy - took an afternoon to do
Post #314575 24th Feb 2015 9:25am
^ Lets see a pic then Smile
Post #314579 24th Feb 2015 9:47am
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Re: 2007 differences
Topvar wrote:
Great post
Few comments to add
Your welcome, glad my instructions helped.
Your correct on the later facelift (06/07 onwards) you don't need to cut the wings as land rover modified them to fit the 07 style headlights
Looking forward to seeing a photo!
Matt
Post #314725 25th Feb 2015 9:45am
Chillb
United Kingdom 2008 Range Rover Vogue TDV8 Rimini Red
Matt
What was the cost of all the parts in the end Question
Unbelievable looking, still struggling to comprehend it took an afternoon for a result like that, as Alanm3 said why fork out for a newer 201 model.[/code] Porsche 993 Targa, Buick Skylark Convertable 1968
Post #314887 25th Feb 2015 10:15pm
An afternoon's work! Shocked Shocked Shocked
Post #314889 25th Feb 2015 10:19pm
Chillb
Ok, a day Rolling Eyes I exaggerated slightly. Porsche 993 Targa, Buick Skylark Convertable 1968
Post #314899 25th Feb 2015 11:37pm
mattstevenson2005
To be honest I can't remember the exact costs but I am a perfectionist (as you can tell) and didn't want any sratches or marks on the new parts so I purchased all the parts brand new from Land Rover. Each headlight was around £700-800, rear lights were £170 each, grill/vents were about £300, wiring looms, new washer tank system, brackets, interface units came to about another £400-500 so all in all was around the £3000 mark. Still looks amazing and turns heads everywhere I go even almost a year later. People think it is brand new and have no idea and can't belive that its 12 years old and has just broken the 100,000 miles mark.
P.S just as an update for members that follow and enjoy my upgrades and enhancements, I have finally completed the move into my new house after 12 months of renovations and building work so it's time to work on the car again! Very Happy Very Happy
The in car PC project that started a few years ago to replicate the 2010-2013 entertainment system has taken some interesting steps and I have made some very good progess. Without going into to much detail on this thread I am in the process of completely rewriting the software (rather than using a third party software with a custom skin as was the previous version but had some fundamental and crucial limitations) the software will be custom built to support 2002-2005 (pre facelift) range rovers and will provide a near exact replica of the latest entertainment system software, it will allow connection and control of all the range rovers factory audio systems and anything else that I can get it to tap into over the cars networks.
For those interested in completing the full 2012 facelift look complete with entertainment system.....watch this space!
Matt
Post #314904 26th Feb 2015 12:25am
Riverstick
Ireland 2015 Range Rover Autobiography SDV8 Santorini Black
Excellent thread Mat....Can you please do a write up on the rear end facelift? 2008 Range Rover TDV8 435,000kms
2015 Range Rover L405 SDV8 Autobiography
2008 Ford Focus1.6 tdci Titanium DPF deleted
Post #314905 26th Feb 2015 12:32am
rear end facelift is just replacing the light units, isnt it ? ... - .- -.
Post #314924 26th Feb 2015 8:16am
n1cktdv8
Topvar - you have pm Thumbs Up
Stan - badgework too I think went to a bright silver on some of the darker colours I think...if you class that as rear end only ! Is this where I put the car details and a bit about myself ?........
Post #314944 26th Feb 2015 10:38am
Riverstick
Very true Stan,
However, I'm always interested to hear someone else's experiences...especially with the wiring/electronics end... 2008 Range Rover TDV8 435,000kms
Post #315013 26th Feb 2015 6:48pm
mattstevenson2005
I didn't really take any photos of the rear conversion as it is really simple but here goes from memory:
I used the interface boxes you can purchase from eBay to allow the new 2010 style lights to work correctly.
1 remove 2 bolts holding old lights in from tailgate area.
2 carefully slide old lights out and disconnect
3 use a small drill to remove the spot welds for the old brackets that hold the lights in.
4 remove the old brackets.
5 offer up the new lights and mark where you need to drill the new grommet holes in the bodywork.
6 fit the new grommets and connect the wiring connector to the nights and secure with the bolts removed earlier.
7 follow the instructions that come with the interface boxes to cut and splice them into the rear light wiring loom, make sure you solder and heat shrink any exposed connections.
8 switch lights on and test all features work.
9 sit back and admire your handy work! Cool
Matt
Post #315535 1st Mar 2015 10:46am
Riverstick
Thank you Matt,
Did you needresistors for the tail light or indicator circuits? 2008 Range Rover TDV8 435,000kms
Post #315541 1st Mar 2015 11:11am
mattstevenson2005
Hi mate
thats what the interface units are, they contain all the resistors for the tail lights/fog/indicators
these are the interface boxes i used http://www.ebay.co.uk/itm/Range-Rover-L322...259f19272d
Matt
Post #315547 1st Mar 2015 11:24am
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Awesome guide Matt and convinced me to facelift rather than upgrade at a huge cost (the FF i mean, not the missus)
Just wish you was my neighbour Whistle
Post #326341 6th May 2015 1:44pm
