Home > In Car Electronics (L322) > 2003 Vogue - DSP removal - no sound - sound |
mbmarkyb Member Since: 18 Jan 2015 Location: basingstoke Posts: 22 |
all i will update the picture as its not showing and take a new one and add in, sorry the other pictures are upside down too.. not had a good post |
16th Feb 2015 7:53am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3966 |
That's an interesting way to avoid having to replace a £300 DSP unit. |
16th Feb 2015 10:18am |
Steverr Member Since: 27 Oct 2013 Location: Bristol Posts: 191 |
So you don't have to use the original DSP then ?? |
16th Feb 2015 9:23pm |
thats right. dsp removed from mine now ...appoligies I've still not posted up that new picture |
22nd Feb 2015 1:40am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7733 |
I'm sure I read that the BM54 switches modes from providing low line level speaker outs to speaker level amped outs if it does not see the DSP on the ibus. Just like a car without DSP from factory. So if that's true, you could run from the bm54 for car speakers. The sound would be better with a great big multi channel amp in with crossovers in though.
22nd Feb 2015 9:34am |
in the summer I will add a better amp . as you say a 4 ch . I have the low and high color codes some where for the speakers so I will make a better job of it . but I currently won't upgrade the head unit as need to spend some money on tyres etc and i'm using the trip computer . my ipod via signal is pretty good. thought I'd also fixed the gos but it still freezes now and again . It had a furry board inside which I've cleaned |
22nd Feb 2015 11:47am |
Gazhay Member Since: 16 Mar 2015 Location: South Wales Posts: 4 |
Hi, do you know what plug carries the speaker cables ? So I can tap into them and use a after market amp?
16th Mar 2015 2:29pm |
