Home > In Car Electronics (L322) > 2003 Vogue - DSP removal - no sound - sound
mbmarkyb
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
I purchased my L322 vogue with not much of the audio system working.
I have done all the usual fixes (pin broken etc) and still no sound.
Have a long trip coming up next weekend so a must was a radio.
I plan at some point to change to the android system but there was always the question of this DSP unit.
I am no audio expert or sparky so you may not want to try this at home.
I set about cutting the wires of the 2 smaller plugs with the thought that the radio audio output must be one of these.
The 2 pairs of wires shown below are the radio audio ones and in my crude way of finding these i used a separate speaker.
I took the other plug with all the speaker wires on it and spliced these between the 2 radio connections , i added a small amp and sub that i had lay around the garage using the (big black DSP connector) red power cable from the DSP connection the white 12v radio on cable and the brown earth.
sound is pretty good considering and the next phase will be a better amp.
Post #312956 16th Feb 2015 6:51am
mbmarkyb
all i will update the picture as its not showing and take a new one and add in, sorry the other pictures are upside down too.. not had a good post Smile
Post #312957 16th Feb 2015 6:53am
That's an interesting way to avoid having to replace a £300 DSP unit. Thumbs Up
Post #312990 16th Feb 2015 9:18am
Steverr
United Kingdom 2003 Range Rover Vogue Td6 Zermatt Silver
So you don't have to use the original DSP then ??
Post #313132 16th Feb 2015 8:23pm
mbmarkyb
thats right. dsp removed from mine now ...appoligies I've still not posted up that new picture
Post #314230 22nd Feb 2015 12:40am
mjdronfield
I'm sure I read that the BM54 switches modes from providing low line level speaker outs to speaker level amped outs if it does not see the DSP on the ibus. Just like a car without DSP from factory. So if that's true, you could run from the bm54 for car speakers. The sound would be better with a great big multi channel amp in with crossovers in though.
Have you downloaded RAVE ? It has all the wiring diagrams in it. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #314253 22nd Feb 2015 8:34am
mbmarkyb
in the summer I will add a better amp . as you say a 4 ch . I have the low and high color codes some where for the speakers so I will make a better job of it . but I currently won't upgrade the head unit as need to spend some money on tyres etc and i'm using the trip computer . my ipod via signal is pretty good. thought I'd also fixed the gos but it still freezes now and again . It had a furry board inside which I've cleaned
Post #314292 22nd Feb 2015 10:47am
Gazhay
United Kingdom 2002 Range Rover Vogue Td6 Zambezi Silver
Hi, do you know what plug carries the speaker cables ? So I can tap into them and use a after market amp?
Any replies are greatfull,
Thanks,
Post #318261 16th Mar 2015 1:29pm
