Home > Maintenance & Mods (L322) > Battery charging
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Battery charging
I'm looking to get a CTek charger and looking on line it is clear there are far too many to choose from.
1. I'm not trying to recharge a discharged battery, just looking to keep my current battery in as good a condition as possible so wondered is a 5 amp charge rate is good enough or do a HAVE to have a 7 amp. I don't do many miles - perhaps 50 each weekend.
2. as my FF is a weekend car and I will want to leave the charger attached for a 4 or 5 days at time - does this mean I need a charger which has a 'maintenance charging' function
There is nothing wrong with my car at present - just trying prevention rather than cure. Thumbs Up
Many thanks 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #313920 20th Feb 2015 2:24pm
MSX5 would be more than adequate for your intended use.
MSX7 will recharge a low battery more quickly but that's all.
You can connect either to your car / battery and leave it connected for as long as you like. Thumbs Up
Post #313945 20th Feb 2015 4:00pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Just a question, interested in getting a CTEK but my battery is a 110Ah, but it says :
Quote:
The MXS 3.8 is an advanced microprocessor controlled battery charger with patented Float/Pulse maintenance for use on batteries from 1.2Ah up to 80Ah. The MXS 3.8 solves a broad range of battery problems and is the ideal charger for everyday use. Features of the MXS 3.8 include diagnosis of battery condition to establish if it can receive and retain charge, patented automatic desulphation program and a special "Snowflake" mode for optimum charging on cold winter days.
Looks like the MSX 5.0 is the bare minimum for a diesel? Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #313948 20th Feb 2015 4:02pm
The MSX5 is adequate for a 110AH battery according to Ctek themselves although I personally have the MSX7 which gives a bit more leeway.
http://mccormicktools.co.uk/ctek-mxs-50-sm...wgodH2MA-Q
Post #313953 20th Feb 2015 4:43pm
ajac8
Thanks Gents
That link is perfect. Just download the PDF manual and all is now clear.
thanks again 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #313955 20th Feb 2015 5:42pm
I have an MXS5 and have done for two years now and its done a load of batteries Smile
So far there are only two that it hasn't brought back from the dead in cars that had been parked up and let go flat for a VERY long time.
I also made up a tow socket adapter for it which makes things easier but requires you have twin electrics Smile
There is also the normal connection in the boot where i used the supplied easy connector onto the main positive and earth on the fuseboard in the boot as this can help with Park heat when used as while 5amps isn't a lot it does help keep the battery good when its used Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #313959 20th Feb 2015 6:53pm
mmiata
Hungary 2012 Range Rover Vogue TDV8 Buckingham Blue
As I see you have a 2010 TDV8 so I suppose you might have an AGM battery. (adsorbed glass mat)
From the current CTEK lineup only the 5Ah is able to perform "AGM recondition".
Neither the 3.6 not the 7 or highers have this AGM recond function.
What they suggest is an annual recond for each battery, what could be made only with the 5Ah. 4.4 TDV8 Vogue Buckingham Blue MY12
from Hungary
Post #313972 20th Feb 2015 9:06pm
mjdronfield
I have the 7 and it's never missed a beat.
I do about 50 miles in the week.....
Mine has an AGM setting
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #313976 20th Feb 2015 9:38pm
mercs600
England 2002 Range Rover Vogue Td6 Java Black
I looked at the full rnge and went for the MX10 - does everything - I leave it connected for months at a time with no problem. Checked on Ebay and found out by searching the seller (Plymouth batteries I think it was) , got it far cheaper than any listing from their actual website (not their Ebay shop) - next day delivery to ! Cannot recommend it highly enough Thumbs Up Very Happy
Post #314025 21st Feb 2015 2:12am
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
+1 for the MX10... Thumbs Up GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #314061 21st Feb 2015 10:00am
Jim_m_kidd
2015 Range Rover Autobiography SDV8 Loire Blue
Related - just wondering when the switch to the AGM battery's happened?
Post #314063 21st Feb 2015 10:02am
Approx 2010 as a lot left without them but were then recalled and the FBH timer was also reduced as they were killing the battery.
IMO i think the actual issue is that when the Park Heat command is sent, instead of just waking up the climate systems it wakes up a few others and this then causes the battery to get pulled down.
This or there is a component in the climate system that uses a HELL of a lot of juice compared to the slightly older setup... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #314131 21st Feb 2015 4:01pm
ajac8
I've just been and checked.The battery is a LR badged Varta and part of the reference labelling says 'AGM' so yep you're right.
Does the CTek have to be 'told' the battery is an AGM or does it just do its thing anyway?
Cheers 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #314162 21st Feb 2015 7:00pm
Weegie
You select AGM in "mode". John
GAP iiD BT-Sold
Post #314164 21st Feb 2015 7:14pm
ajac8
Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #314165 21st Feb 2015 7:15pm
