Home > Technical (L322) > Iid Bt tool |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 790 |
How do you know if your vehicle has this pre heat thingy ?? |
20th Feb 2015 5:23pm |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1698 |
All the diesels have it (to pre heat the engine basically)
20th Feb 2015 6:05pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Peter noting you can do i'm afraid , it's an anti carjacking feature ( whatever) you will just have to get used to hitting the button below the hazard lights switch .
20th Feb 2015 11:47pm |
crispy2 Member Since: 18 Aug 2013 Location: Mandurah Posts: 102 |
Ok, thanks for that Axle. I would agree with your theory that cable failure is caused by over use - I will use the centre button for the opening function. I'm puzzled about no auto unlock with key removal - it would make sense that if you just removed the key (and maybe interlocked with the Trans selector in Park) then auto unlock would be a logical and safe thing to do as was the case with the D3.
21st Feb 2015 5:54am |
Pete
21st Feb 2015 7:57am |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 |
Is it some thing the gap tools programmers can incorporate in an update? _____________________________________________________
21st Feb 2015 8:34am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
they cant cos that feature isnt in the original firmware...its the same with the folding mirrors, it would be nice for them to fold automatically on lock but this also cant be done.. ... - .- -.
21st Feb 2015 8:37am |
Can they be custom programmed Stan by gap then updated? _____________________________________________________
21st Feb 2015 8:39am |
hopefully i'm wrong but from what i've read, no...
21st Feb 2015 8:40am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Park the car in a carpark at night. Turn engine off and remove key (D3 unlocks) passenger doors are now open to an assailant... Same scenario in a FFRR and your passenger doors stay locked! Its the same as "single point entry" It bugs some people... Not others! BUT, is much safer if your wife walks back to the car in the dark car park, presses the unlock button and only the drivers door unlocks... She has piece of mind! Obviously JLR think that D3 owners are NOT worth robbing! |
21st Feb 2015 9:06am |
Wife in MY RR haha no f#*^%€•g chance! And no dodgy parking for me 😜 _____________________________________________________
21st Feb 2015 8:47pm |
Scott, Stan is correct. It can not be done (actually anything can be done, but the cost would be more than unreasonable). The IIDTool just provides access to soft switches that do not otherwise have a user interface. The soft switches themselves are programmed into the ECU software by JLR. In order for us to do custom programming, we'd have to reverse engineer the ECU software, modify it, and provide the option of reflashing the new software to the ECU. To reverse engineer the software of even the most simple ECUs requires a time investment costing well into the 5 figure range. This is essentially what chip-tuning (chipping, remapping, etc) is. On the ECM it is justified because, if you are a good tuner, you can sell many remaps at 4 figure prices. Door lock options will not create that sort of demand nor allow prices like that... RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
25th Feb 2015 10:37am |
I seem to remember from playing with the Faultmate (sorry Steve, didn't know about your system at the time as it was pre-FFRR forum for me) that you can select it the unlock on engine off. Which would indicate that it is programmed in the ECU. Since I don't have access to my 2006 nor do I have it linked to that VIN (it is now linked to the 5.0 SC VIN) I am not in a position to check.
25th Feb 2015 10:48am |
