Home > Technical (L322) > Iid Bt tool |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6723 |
Take a look at GAPs website, all the options that can be changed are there.
19th Feb 2015 10:59am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35281 |
i've ,
19th Feb 2015 11:01am |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1698 |
@Stan - Where did you find the volume control for the PDC..?
19th Feb 2015 11:14am |
PAM-parking aid menu Ash... ... - .- -.
19th Feb 2015 11:16am |
Ash
19th Feb 2015 11:18am |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 |
I'm not a lard arse and can get in and out with having the steering column doing it's retracting act so i'veswitched off the retractable steering column as i've seen a few posts where the column has got stuck, meaning the car isn't driveable.
19th Feb 2015 11:58am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
Enabled park heat, so I can set the FBH to come on in the morning. Have Aux Heat / Vent on the menu now
19th Feb 2015 4:50pm |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 |
19th Feb 2015 6:21pm |
That'll be the kiddie then Evro
19th Feb 2015 6:45pm |
Mines an early car, so the fbh system may be slightly different activation wise..... 2011 Range Rover Vogue SE 4.4 TDV8
19th Feb 2015 6:59pm |
@Ash, is it in the FF's dash menu perhaps.. ... - .- -.
19th Feb 2015 7:02pm |
Thx Stan - will have another look
19th Feb 2015 10:41pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
RTFM
19th Feb 2015 10:46pm |
Not if you also do the dash reset - it appears straight away then (or did on mine) I was also advised of this by my local LR indy Ash
19th Feb 2015 11:11pm |
