Home > Technical (L322) > 'Hunting' rev counter |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Hi all,
18th Feb 2015 9:41am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35312 |
any associated engine noise increase/decrease with that Neil.. ... - .- -.
18th Feb 2015 9:42am |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1253 |
Torque Converter?? |
18th Feb 2015 9:49am |
I knew I should have turned Kreator down .....
18th Feb 2015 9:50am |
It's only done 110,000 miles .... and the gear changes are fine (although now you mention it this morning it did seem to hunt around for the correct gear in the 30.....) Land Rover Addict
18th Feb 2015 9:51am |
These might be worth a read. Maybe not but you never know.
18th Feb 2015 9:56am |
Bad etiquette I know replying to my own posts, but would an injector 'miss' be logged by IID? Land Rover Addict
The eventuality is catered for with Code P0202
18th Feb 2015 10:02am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16286 |
Torque converter would be my first point of call too... |
18th Feb 2015 10:07am |
I'll check the air hoses around the MAF's - turbo hoses are fine and there's just the normal diesel mist on hard acceleration - no clouds.
18th Feb 2015 10:10am |
If it does the same again I'll get it booked in then, I'll still do a visual check of the engine compartment as it was recently serviced and I didn't do my usual check over as it's been dark whenever I get back from work Land Rover Addict
18th Feb 2015 10:14am |
Have you had the auto box serviced? |
It hasn't been serviced in my ownership, I will have to check the paperwork I got from the LR Dealership that owned it before me. I was under the impression that these things are sealed for life, moreso than the old ZF's I had in my Discovery V8?
18th Feb 2015 10:29am |
@DMRR,
18th Feb 2015 10:45am |
Yeah it is - so it's under any of those recommendations. I live quite close to the ZF place so I'll ping them a mail or visit if it does it again and I can confirm transmission.
18th Feb 2015 10:49am |
