Home > Technical (L322) > engine system fault TDV8 |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 |
Forgot to mention, although it's only done 5k since service, the service date is flashing up also, and has been for a while, are the two connected?
14th Feb 2015 4:34pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8516 |
Battery, then top turbo hoses as a place to start. As these are easy to access, replacement instruction in the wiki. Take them off and check for cracks or splits, especially under the protective mesh.
14th Feb 2015 4:45pm |
NMJ
14th Feb 2015 5:42pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
If it's doing it at start up when cold it could be the start of an EGR issue! Best not to cane it I case you do damage to the turbos... Get codes read asap my friend... |
14th Feb 2015 5:48pm |
Craig has a point, and is more likely the problem, but worth checking the easy stuff first.
14th Feb 2015 5:55pm |
Exactly... Hopefully it will be a pipe split BUT!!! Don't cane it, that's important |
14th Feb 2015 6:02pm |
If it is something like the egr, will it not go into failsafe mode? |
14th Feb 2015 6:29pm |
Err, no...
14th Feb 2015 7:39pm |
In a BIG & expensive bang!!!!!!! |
14th Feb 2015 7:54pm |
That's reassuring to know |
14th Feb 2015 7:57pm |
Fault codes read my friend... Egrs are reasonable, turbos and ingested vanes are not. There is nothing that can't be fixed with a hammer😜😜
14th Feb 2015 8:00pm |
Thanks guys
14th Feb 2015 8:16pm |
Battery now fully charged again, started her up...no faults
15th Feb 2015 11:21am |
Sql Member Since: 27 Jun 2015 Location: Poland Posts: 242 |
Did you ever get to the bottom of it? My tdv8 started to show "engine system fault" message at first morning start for a brief moment. After a second or two it dissapears and does not appear again throughout the day. 07 3.6 TDV8 Vogue
26th Jan 2017 3:18pm |
